| first built but not the last | |
steeldaytonas Member
Age : 41 Join date : 2015-10-23 Points : 3406 Posts : 77 Location : petawawa,Ontario, Canada
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7313 Posts : 2914 Location : Ontario Canada
| Subject: Re: first built but not the last December 5th 2015, 10:49 pm | |
| yea Im made by hand but its a 2'' round stock with 3/4'' hole made on a lathe welded on a 1/4'' plate . I align all the holes on the plate including the center hole and use a 3/4'' bolt to align the plate and the round stock together and finished by weld it square. I made the rear hub on the same way but I had few threaded hole to put locking bolts who are align with the original channel key of the axle shaft.
I will send some more pics soon. I have to disassemble it to do the fine work one it because now I just done the preliminary built the make everything work and fit together so I will take good pics for you guys
Age : 34 Join date : 2013-11-02 Points : 7164 Posts : 2910 Location : New Jersey USA
| Subject: Re: first built but not the last December 14th 2015, 7:36 pm | |
| hum I use the one at my job so I have to look the brand but ruffly its mid size professional machinist lathe it could handle 6'' round stock on about 4foot long. Im not a pro with machining but I know enough to do what I need, sorry if its not super accurate info | |
| Subject: Re: first built but not the last December 15th 2015, 7:28 am | |
| pretty much yes we have it in a military shop to provide support to the vehicle maintainer | |
| Subject: Re: first built but not the last December 19th 2015, 3:39 pm | |
| what have to be fix: loose in steering system better fender trim enlarging front axle and rubbing trim air filter carb adjust tranxle rebuilt finish batterie rack add hood lock
mod I want to had: alternator light larger seat (to sit my son with me) locking rear axle winch bumper rear rack adding bearing on front hub adding electric fan Radio and cup holder | |
| Subject: Re: first built but not the last May 19th 2016, 8:38 pm | |
| Still in one piece huh? Are those front wheels cragers? I have a set of 4 of those with some rust. Didn't find any use for them yet though. | |
| Subject: Re: first built but not the last May 19th 2016, 9:50 pm | |
| yeap still in one piece but still some stuff to improve like brake, steering, intake and the accesories. and yeap hteyr cragar I have the rear one to but I have a problem to fit them due to the shifter position so I try to figure it out I think I plan enough stuff to do on it to put it in the built contest but I still have a lot to do on my Overkill built
