| my custom built rc projects | |
2020 Build-Off Top 3 Winner
Age : 48 Join date : 2018-05-05 Points : 2981 Posts : 518 Location : S. Illinois
| Subject: my custom built rc projects May 16th 2018, 12:49 am | |
| i have been working on 2 rc crawler projects over the last year, one for me and one for my brother, first i will post up mine since i have a few more pics of the progress on it. i had a plan for this rc crawler for a long time, but money issues kept it as just a plan in my head, then i caught a financial break so to speak and have since had a little extra cash, so i started the long imagined scale crawler i wanted to build about 5 or so months ago, the original plan was to build something like this " /> but plans change and i went a slightly different route. the 1st step was to get 2 Tamiya blackfoot bodies and destroy them, then put them together. at this point i realized i can't cut straight " /> but a little body filler some sanding and a coat of primer gave it a much better look " /> then it was time for color, i like purple but didn't want just any common purple, i wanted something that had some flash, some thing that really popped that's when i found this " /> krylon shimmer metallic candy purple metalflake, but after painting i felt it needed something else and added the testors metallic silver, but the plain black wheels didn't look right now, so i went at them with the same silver i used on the body, and now it looks much better, at least i think so " /> it sits on a scx10 chassis held on with magnetic body mounts, it has 75mm integy internal spring shocks and a narrowed rear axle, the wheels are slightly modified, i narrowed the hubs, 1.9 level3 rc dually wheels, and the 96mm tall tires are cheapies i found on ebay, some parts are still temporary, like the rear lower 4 links, i have yet to get the transmission, drive shafts and electronics, except the servo which i stole from my Tonka roughneck rc conversion project, i may post more on that later, | |
| Subject: Re: my custom built rc projects May 16th 2018, 1:14 am | |
| now for the truck i'm building for my brother, i built this body 2 years ago and gave it to him for his birthday, like my f350 above it started out as 2 Tamiya bodies, but they were 50s style f100 midnight pumpkin bodies not the newer style blackfoot f150 bodies i used for mine " /< he put it on a shelf and after nearly 2 years decided to build it into a functioning rc, the plan is to go with an old school military look, but with a more hardcore off roader flair, sort of like it was a military truck turned into a civilians trail rig, so i started modifying the redcat Everest 10 chassis he had been running for several yrs, it just didn't sit right with the stock wheelbase of the redcat " /> i have since shortened the wheelbase so it fits almost exactly, i don't have any pics with the new wheelbase atm, i didn't have to narrow the axles the width was pretty good and fit his plans for the way it would look when finished " /> all the chrome will be painted olive drab like the body, i was able to use almost all stock parts from his original crawler, i had to change the upper 4 links and make them the lowers to get the wheelbase right, and then made new upper links with allthread, he still needs drive shafts and body mounts to make it a runner, and the rest of the body parts (grill, windows, roll bar bumpers, tailgate) to complete the truck | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8582 Posts : 5190 Location : Ontario Canada
| Subject: Re: my custom built rc projects May 16th 2018, 1:18 am | |
| That first one is a pretty nice looking rig! Does it have a parallel 4-link? Or is it a triangulated setup? I'd love to see a view of the underside chassis stuff. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: my custom built rc projects May 16th 2018, 1:22 am | |
| - AllisKidD21 wrote:
- That first one is a pretty nice looking rig! Does it have a parallel 4-link? Or is it a triangulated setup? I'd love to see a view of the underside chassis stuff.
double triangulated, with the upper 4 links as the main centering links, it's a standard axial scx10 setup, found on the gen1 scx10 trail trucks | |
| Subject: Re: my custom built rc projects May 16th 2018, 1:26 am | |
| Oh okay, so you don't have to run a track bar on the axles either. Neat stuff! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5748 Posts : 1993 Location : Northern Ireland
| | | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5487 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: my custom built rc projects May 16th 2018, 11:59 pm | |
- Oh okay, so you don't have to run a track bar on the axles either. Neat stuff!
not with the setup i usually run, there are several factory trail trucks out that do use a track bar with a single upper link, the new version scx10 2 uses this 3 link/ track bar setup in the front | |
| Subject: Re: my custom built rc projects May 17th 2018, 12:02 am | |
- Those are sweet man! Love the old Ford shapes, glad you're using them.
my 2 favorite truck body styles are the mid 50s ford and the 78-79 ford | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
