| troy built 4X6 flatbed ratrod | |
+4willis923 Angchor Doug THESEARSREAPER 8 posters |
THESEARSREAPER New Member
![THESEARSREAPER](https://2img.net/u/2812/37/66/46/avatars/1839-86.jpg)
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | |
Doug Site Owner
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 16th 2014, 10:07 pm | |
| Fixed your pics, kinda.
Looks good. Only worries I would have is rear weight with the axle so far up front, it might tip to the rear. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Angchor Member
![Angchor](https://2img.net/u/2812/37/66/46/avatars/1672-45.jpg)
Age : 67 Join date : 2014-04-14 Points : 4345 Posts : 491 Location : Index, Washington
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 16th 2014, 10:24 pm | |
| - Doug Fackler wrote:
- Fixed your pics, kinda.
Looks good. Only worries I would have is rear weight with the axle so far up front, it might tip to the rear. Actually, moving the weight of the axle/tires/wheels further forward, makes the overall effect less tippy toward the rear. | |
willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 16th 2014, 11:14 pm | |
Looks good. Only worries I would have is rear weight with the axle so far up front, it might tip to the rear. Actually, moving the weight of the axle/tires/wheels further forward, makes the overall effect less tippy toward the rear. can you elaborate on that? unless im stoopid, you want the rear axle as far back as possible, without compromising the wheelbase, making you bottom out. if you have too much weight behind the rear axle, its going to just do wheelies, especially if there is weight on the flatbed | |
richie thomas Veteran Member
![richie thomas](https://2img.net/u/2812/37/66/46/avatars/156-8.jpg)
Age : 29 Join date : 2011-08-04 Points : 6326 Posts : 1434 Location : east dublin georgia
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 16th 2014, 11:56 pm | |
Looks good. Only worries I would have is rear weight with the axle so far up front, it might tip to the rear. Actually, moving the weight of the axle/tires/wheels further forward, makes the overall effect less tippy toward the rear. can you elaborate on that? unless im stoopid, you want the rear axle as far back as possible, without compromising the wheelbase, making you bottom out. if you have too much weight behind the rear axle, its going to just do wheelies, especially if there is weight on the flatbed i must be stupid to, cause i would thing that a Longer wheelbase would stop the tipping, damn, i reckon i did mine wrong, | |
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 16th 2014, 11:58 pm | |
| the axle gunna b on the back and the weight gunna be more in the bake and ima butting sand in my front tires to help with the waite and the 18hp opposed twin well help with some of the waite and the gas tank is going on the front also cus the engine takes up the whole underneath of the hood | |
Angchor Member
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 1:19 am | |
| Must be a whole lot of stupid going around, then. Cuz I obviously got some on me, too.
What I saw in the pics was a tractor frame with a long extension on the front.
If you take a tractor, with the rear axle in the normal place... Put an extension on the front, and move the front axle out there... You have more weight out front, and less chance of a wheelie.
Sounds like that is not what is happening in the pics??? | |
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 1:41 am | |
| it is lengthen just added new metal to make it look stock to put the dash on to put the original steering on in this pic it show that it was lenghthen but I added some metal on it to make it look like its not https://i.servimg.com/u/f39/18/93/27/75/hrthyr11.jpg and one axle is stock place the other is back about 6 inches and all those pipes is gunna be cut in half and not be that long | |
Craftsman1998 Veteran Member
![Craftsman1998](https://2img.net/u/2812/37/66/46/avatars/1167-45.jpg)
Age : 26 Join date : 2013-10-30 Points : 5078 Posts : 1068 Location : New jersey
Angchor Member
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 2:44 pm | |
| I don't think there was any "stupid" involved at all. I think it is just a matter of we all got different pictures in our heads, when we read the description, and saw the pics. LOL My own misconception probably comes as a result of not thoroughly reading. This is a crude drawing of what I pictured in my head: ![troy built 4X6 flatbed ratrod That10](https://i.servimg.com/u/f39/18/82/53/07/that10.jpg) Add some frame, to the back, to support the second axle. (4x6) Then add some metal to the front, to support putting the ladder out there, which I assumed was to move the axle out there. This... Would definitely not be more prone to flipping backwards. ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png) Now that I re-read the title, and look again at the pics, it looks like the 'ladder' is on the back, and that fits with 'flatbed' in the title. If that ladder is going to hang off the back, as a flatbed, then I agree... you need to put another axle back there, or it will always be on the ground. Not just at wheelie time. This is what the picture in my head looks more like, now. ![troy built 4X6 flatbed ratrod Now10](https://i.servimg.com/u/f39/18/82/53/07/now10.jpg) Could still be completely wrong... | |
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 3:36 pm | |
| that ladder is getting cut off it was off my drag mower that why its on there and I understand what yall saying the seat and stuff is moving up and the bed gunna be on top above the axles | |
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 9:13 pm | |
Last edited by willis923 on July 17th 2014, 9:44 pm; edited 1 time in total (Reason for editing : pics) | |
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 10:45 pm | |
| that looks like it will do pretty good. take a look at Richie Thomas's mini Deuce & 1/2 if you run into a problem. maybe he can help you | |
CornShuck4CE Member
![CornShuck4CE](https://2img.net/u/2812/37/66/46/avatars/1654-21.jpg)
Age : 35 Join date : 2014-04-07 Points : 4162 Posts : 337 Location : Woodville Al
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod July 17th 2014, 11:40 pm | |
| The only thing i see is the distence between the rear tires may make it hard to turn. But i like it. | |
jonnya Member
Age : 48 Join date : 2014-08-19 Points : 3786 Posts : 95 Location : Norfolk, England, UK
![troy built 4X6 flatbed ratrod Empty](https://2img.net/i/empty.gif) | Subject: Re: troy built 4X6 flatbed ratrod August 25th 2014, 11:21 pm | |
| What happens regarding Ackermans steering angle when you have two rear axles? Which of the rear axle's centrelines do the steering arms point towards? | |
