| Keizer the Little Cub Cadet 122 is growing up | |
+10Murraymountain Gtx106 TheBeal diddie Cheesedawg82 mowerjunkie03 prancstaman Crazy_Carl AllisKidD21 Mister_Studabaker 14 posters |
mowerjunkie03 Member
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 6th 2019, 10:47 am | |
| I am so glad I stumbled apon this thread. From what little footage I have seen of this tractor I am super impressed. It's great to see a Cub hittin the trails with the rest of them. This build reminded me that you don't need a Wheelhorse or a Sears to make a great trail rig so that inspired me to start work on my Bolens 1050 again.
Some questions I have are you running the stock clutch? And is it tough enough to take all that power and abuse? Did you increase the gearing? I have seen blueprints for a custom driveshaft and clutch design for Cubs designed for pullers and I have wondered if that is necessary for offroading. Sorry about all the questions. I am not that knowledgeable about Cub Cadets. Thanks. | |
Mister_Studabaker Member
![Mister_Studabaker](https://2img.net/u/2812/37/66/46/avatars/3392-47.jpg)
Age : 56 Join date : 2019-03-15 Points : 2145 Posts : 118 Location : Grand Rapids, Mi.
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 6th 2019, 11:39 am | |
| @mowerjunkie03 Thank you glad you found Keizer impressive. Please ask all the questions you wish it is absolutely no problem. My answers tend to be way overboard so my apologies in advance. It depends if you like to clutch dump and do wheelies than no way will stock hold even on stock 16hp trim. Keizer's clutch has been designed to handle just that "Wheelies in top gear and motor cranked" so far 24hp, 27" tires and 47% overdrive gear setup and still holding. It is a two stage engagement with two disks that delivers lower clutch pressure and adds feel to the mix. Was able to make it on the cheap as well. Pulling the motor in and out all the time with cubs stock drive line set made for challenging installs and removals. Something had to change so the drive shaft was modded to help with that. Installed a constant velocity joint from a newer cub which had the bigger diameter drive shaft too, perfect for what was about to happen to it. "Big RPM clutch drops" Woods running a good clutch is needed to help clear out your tires to either get out or go deeper or to bounce over a log. When you have inches to a foot to get the "get out jail free card" there is no room for clutch slippage. Found this out the hard way missed dinner and got laughed at. Still funny today. Wrote up a little story about that on FaceBook's Cleetus joe along with other mods done to Keizer. Pulling clutches are way to pricey that require major spring pressure to hold them and they have no feel. No thanks. Cheap strong and holds a ton literally with little pedal effort. Best Regards, Mister Studabaker PS thank you for your interest and stay tuned lots more content coming this way. | |
![mowerjunkie03](https://2img.net/u/2812/37/66/46/avatars/3330-36.jpg)
Age : 20 Join date : 2018-10-29 Points : 2522 Posts : 342 Location : Burnt Ranch, California
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 6th 2019, 8:20 pm | |
| Wow thanks for the response. I am glad to see this whole new level of professionalism brought to the mower modding community. I hope to some day have the knowledge and skill tk innovate on this level.
I this clutch design something that could be used on other GTs with sprockets and chain do away with slippage? | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 7th 2019, 5:47 am | |
| @mowerjunkie03 Just by asking questions puts you well on your way. Ok at a loss here and need your view to see if the clutch can be retrofitted for your use. Space constraints for the cub setup roughly 15"x12". ![Keizer the Little Cub Cadet 122 is growing up - Page 2 Wp_20143](https://i.servimg.com/u/f19/20/05/45/57/wp_20143.jpg) By changing orientation one could put a driven double pulley or sprocket in there somewhere. What do you think? Double pulley would stop most of the belt slippage plus you could add more tension to the belts. That's it love your question, you have earned the question of the week, congratulations job well done. Best Regards, Mister Studabaker Stay tuned lots more stuff heading this way. | |
prancstaman Veteran Member
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | |
Cheesedawg82 New Member
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 10th 2019, 1:21 pm | |
| Seems as if a few folks are confused here, talking about belts and the clutch on a narrow frame Cub Cadet. These machines aren't like what most of you have been working on, they're a genuine miniature farm tractor, with a direct shaft drive, gear box, and rear end borrowed from the Farmall Cub. When this tractor was new on the lot in the '60s, it was priced higher than some cars. | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 10th 2019, 5:55 pm | |
| @prancstaman Its better to list what is left stock, Its a shorter list ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) Pressure plates, release arm, draw bar and the lighter colored clutch disk. The goal is to see if this can hold 30hp. Stay tuned Best Regards, Mister Studabaker | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 10th 2019, 6:34 pm | |
| Very beautiful work! This is gonna be one MAD Kohler. ![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif) ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
diddie Member
![diddie](https://2img.net/u/2812/37/66/46/avatars/2712-63.jpg)
Age : 57 Join date : 2016-10-02 Points : 3356 Posts : 411 Location : Indiana
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 10th 2019, 9:08 pm | |
| - prancstaman wrote:
- That's a neat clutch there. It never occurred to me to put the clutch spring on the shaft like that. Very slick. What part on the clutch did you modify?
cub cadet has always used this design for there manual trans tractors with the spring on the shaft to put the pressure on the pressure plate he didn't create that set up. | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 11th 2019, 7:24 pm | |
cub cadet has always used this design for there manual trans tractors with the spring on the shaft to put the pressure on the pressure plate he didn't create that set up. Yes, stock setup. I never really seen one though. I'm use to seeing and working on car/truck clutch. | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 12th 2019, 2:17 pm | |
cub cadet has always used this design for there manual trans tractors with the spring on the shaft to put the pressure on the pressure plate he didn't create that set up. Bolens has always used this technique as well. This looks alot like a simplified version of the clutch on my Bolens 1050. | |
TheBeal Veteran Member
![TheBeal](https://2img.net/u/2812/37/66/46/avatars/967-1.jpg)
Age : 29 Join date : 2013-06-06 Points : 5643 Posts : 1402 Location : Central PA
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 14th 2019, 3:03 pm | |
| - TheBeal wrote:
- I like to see the engine work. Makes me want to do something to my K341.
![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) Me too. There is a glitch. Doing a modification to the constant velocity joint base flange and input pinion of the creeper gear. The taper and out of round condition that now exist is beyond what retaining compound can cure. I.e. last install left the compound out now it's time to repair. | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 17th 2019, 6:23 am | |
| To cub owners - note the "roll pin" hole.
IH used Spirol, or roll pins. This is a pin that's a small coil of steel, made up like grandma's pumpkin rolls. Don't confuse it with a standard split pin. While they look every similar, they're not the same, and they're not nearly as strong. A split pin is much more likely to shear. | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 17th 2019, 6:53 pm | |
| - mowerjunkie03 wrote:
- This is some beautiful machine work. Good thinking with the JB weld on the intake. Turned out great! Do you have YouTube?
Thank you trying my best. JB weld was used previously in the same port and applied it all in one shot, not a good idea, second times the charm with multiple layers maybe. Youtube handle is: Mr Studabaker or try a search for cub cadet mud mower. Stay tuned more to come. Mister_Studabaker | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 25th 2019, 8:01 pm | |
| Gotta love that low end grunt! She sounds great! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 25th 2019, 8:51 pm | |
| Some of those hillclimbs looked like they might have hurt on all that heavy iron. What kind of seat do you have on her? My 149 could use an upgrade, as garden season is upon us.
Awesome machine, she sounds great!
![Keizer the Little Cub Cadet 122 is growing up - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: Keizer the Little Cub Cadet 122 is growing up April 26th 2019, 6:06 pm | |
| - Mister_Studabaker wrote:
P.S. @AllisKidD21 The exhaust note is even better at a much lower tone.[/size] Ooo boy, I can only imagine! Also I think a walk around video would be great! ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
