 Keizer the Little Cub Cadet 122 is growing up
Gtx106
diddie
Cheesedawg82
mowerjunkie03
Mister_Studabaker
14 posters
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
Keizer the Little Cub Cadet 122 is growing up - Page 6 Empty
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeJanuary 17th 2020, 11:32 pm
@Mister_Studabaker Have you thought about a boosted modification like turbo charging it? I know your always up for new test and mods.
BlakeGroce
BlakeGroce
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 3rd 2020, 5:55 pm
I just read through this and I'm at a loss for words. I thought I had some heavy duty modifications but Keizer makes Brutus look like a chew toy. Very impressive and extremely well built machine there.
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 15th 2020, 10:57 am
@Jeremiah R. Cooper  Thinking about a super charger or laughing gas but those are a ways off.
@BlakeGroce Thank you for the bump.
Keizer is undergoing a few tweaks this month.  The last ride in Ohio Keizer was shown the door on several occasions.  It appears that 380lbs over the skinny front tires may be a problem.  Completed a careful study of ground disturbance i.e. front tire pressure on the ground being felt vs other tractors on the ride and came away with "Oh so that is why Keizer is getting stuck all the time".  Making one change only just to know if this is really the culprit.  Taller and wider front tires.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Psi_ti10
This is the front view with the larger front tire installed to show the difference between the two.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2024
Side view.  Please note there are stock oem spindles that will lower the front approximately 1-5/8" give or take a few. This should put the front end height back on plane.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2025
These are the guys. The one on the left is what is installed currently.  Bonus the one on the right moves the wheel in about a 1/2" and lowers to boot.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2026
The next mod is a bit complicated.  With Cub Cadets being the pulling masters a whole slew of gears became available.  Albeit they favor pulling not off roading and this is where its becomes complicated.  Keizer needs a taller 2nd gear (trail gear and or mud run gear).  Was trying like hell to obtain the proper gear set up but the pullers use a super close ratio gearing set up like one to two gear separation.  This is no good.  The other day it hit me after the hammer smacked my thumb of all things.  You can change first gear to the gear of choice dang near in the middle of 2nd and 3rd.  The creeper is still in the mix and becomes even more usable with this change bonus.
Details will be posted once they are known.
Regards,
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 15th 2020, 11:09 am
Man, you make mud mowers a science!  Great work.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Sig115PROJECTS:
Keizer the Little Cub Cadet 122 is growing up - Page 6 Sig214Keizer the Little Cub Cadet 122 is growing up - Page 6 Sig314
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 15th 2020, 11:24 am
@MightyRaze Thank you, I blame the engineering background, its a real pain in the arse, always forcing me to change out whats not working with what may. Like if the front tire scenario fails to achieve results a rear tire strategy will come in to play, as in the form of new rubber Intimidators 28x10x14's Wink
Regards,
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 15th 2020, 11:01 pm
@Mister_Studabaker those 3/4 inch spindles?
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 16th 2020, 8:54 am
@Jeremiah R. Cooper one inch factory oem spindles. Two kinds are available. Shorty's and the longer one.
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 18th 2020, 9:20 pm
Doing a few things to Keizer
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2029
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2027
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2028
Love the wording on this.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2032
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2030
42" wide Monster of Mayhem, well in the front at least.  The back is next.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2031
Got a big hit here.  Moving the exhaust is on order.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2034
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2033
Would ya know it, found these from a SGT Cub Cadet and they are perfect.  Ya gotta love it when stuff just falls into place.  It makes you feel like a very lucky dude.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2035
Vampire II's sized at 27.11.12 weighing in.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2036
Turf Savers sized at 26.12.12 weighing in.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2037
Its looking better all the time.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2039
Oh sh*t, with all the excitement of tire stuff totally forgot to put the cap on tight and spilled half the contents.  Was wondering why I was so happy hahah...
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2040
Wow! Finally, last tire is on.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2038
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 18th 2020, 10:08 pm
They look pretty nice on there. Looks like the exhaust shouldn't be too much of a problem to re-configure a bit. It's nice that you had spindles available to drop the height back down close to normal.
That should help out in the mud I would think, especially with some speed. I may have missed it somewhere but do the new fronts effect width at all?
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 11:37 am
Are the rear rims the same width just with a different offset or are they wider with a bigger offset?
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 11:48 am
@mr.modified 42" front and 42" rear
@Jeremiah R. Cooper  Same width at 8.5" with a a different offset add 2".  So rim to face is .8" vs 2.8" for the ones taken off.  Can you say super mag.
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 11:59 am
@Mister_Studabaker 42" is a nice stance. Wards rear end is 41" I believe.
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 12:15 pm
All 42 inches of rear view.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2042
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 12:32 pm
Ok that's not too bad really. I'm gonna be right at 42" wide with my new build.
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 12:59 pm
Seems so much wider!
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 2:14 pm
Just re-measured, cause ya know you cant trust a dude working off a high from bead sealer haha, but alas 42" is what was measured today.
Regards,
Mister Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 2:39 pm
@Mister_Studabaker now you got me curious about the Wards and the Jacobsen.
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 6:58 pm
Look at what just showed up today.  OMG! these are even better in person.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2045
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2048
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2047
Fist full of mud
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2046
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2049
Super soft Shore A 75 vs the Vamp II's at Shore A 90.  Sticky tire.
Keizer the Little Cub Cadet 122 is growing up - Page 6 Img_2050
Was going to send these back because there 14's.  Scratch that love a first sight.  Rims ordered.  Basset D rings.
Best Regards,
Mister Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 9:40 pm
OMG, I thought it looked huge with the Vampires II's.
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 19th 2020, 10:00 pm
Probably the meanest looking tires I've ever seen. They oughta look good on there.
Pretty soon you'll be looking for more horsepower to drive all this stuff! Obviously testing will tell, but do you think steering will be more of an issue with the more aggressive tires? Even if it did, might be a worth while trade off depending on the terrain.
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 20th 2020, 8:01 am
Slept with the new rubber and awoke with a name for them.
"The Thompson Twins"
There ho's, they go anywhere and love rolling Keizer and SGT Pepper.
Will see if they can live up to the billing. February 29 ride, the twins may make it down if the rims show up in time.
Best Regards,
Mister Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 20th 2020, 11:48 am
@Mister_Studabaker that's one of those speechless moments when you open the door lol
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 21st 2020, 9:49 am
Yep told the Mrs's all about it and what I was doing.  Shes used to it as long as the toys are along side the bed shes ok.  Love that woman.
Today Keizer is going under the wrench.  Replacing the broken creeper unit that was pretty worn out from the start with a like new Cast iron version and doing a gear change in the trans. Thanks to the pulling community they have made it quite easy to buy gears to do just that.  1st gear is going to be taller as it will be gear ratio wise in between 2nd and 3rd on the old setup.  So 1st becomes 2nd and second becomes 1st.  The creeper finally becomes usable other than as a loading gear onto the truck.
Yesterday found several culprits as to why cubs like to pop out of 2nd gear.
  1.  The top shaft bearing cup and its bearing clamp works for a lesser cub.  Way to much clearance for my taste.
  2.  The splines on the gears itself wear a lot.  Bought two sets of gears plus the one that came out of SGT Pepper and found the wear pattern on the gear splines. The splines are designed to keep the gear centered on the shaft under pressure.  When the splines on the gear itself wear the ability to self align begins to falter and then wobbles on the the top shaft spline and works its way off the gear and pop goes the weasel.
The resolution:
   1.  Replace the ball with a plunger and a stiffer spring for the shift detent to hold the gear in place.
   2.  Tighten up the manufacturing tolerance to be more of a press fit for the top shaft bearing cup and let the clamp system actually clamp the bearing in place instead of holding.  Use of bearing retaining compound here fixes the loose fit of the bearing and a shave of .005 on the cup to be even with the bearing for an actual clamp.
   3.  Use the least worn gear cluster and "SEND IT"
Anticipating lots of wet clay for the upcoming ride this Feb 29 and should be a good test for the above changes.  Wet clay is extremely difficult to traverse as it loads up tires and weighs the machine down. This weight induces tons of pressure in the gear train.
Previous attempts of wet clay traversing in Keizer proved fruitless.  No gear would hold.  Mind you the trans is pretty worn out in its current state.
Best Regards,
Mister Studabaker
Mister_Studabaker
Mister_Studabaker
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 23rd 2020, 11:28 am
Keizer's new shoes are all installed.
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 23rd 2020, 12:34 pm
Holy crap batman! Look at them tires!
PostSubject: Re: Keizer the Little Cub Cadet 122 is growing up   Keizer the Little Cub Cadet 122 is growing up - Page 6 Icon_minitimeFebruary 23rd 2020, 12:43 pm
@Mister_Studabaker they actually cleared the footboards/fenders. Side view of it was looking like a farm tractor. Do you have a link on hand for the 14" rims?
Page 6 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» 2019 Top Tractor Challenge, 8/17 - 8/18 [ATLTF Official Event]
» ATLTF Growing pains.
» Haspin Acres Rally 2019 June 5th - 9th... Join this growing event!
» Old cub cadets
» Cub Cadet 72
