| 1999 Saturn sl1 | |
TheGreenHornet Member
Age : 23 Join date : 2016-04-16 Points : 3416 Posts : 227 Location : Indiana
| Subject: 1999 Saturn sl1 October 23rd 2018, 10:46 am | |
| Hey guys, it's been a while since I've been on here, but I'm working on a project here and need some suggestions/ info. Ever since my f150 took a dump (tranny blew up, that's a story in itself) I've been driving the spare car, which us a 99 Saturn sl1. It has a 4 banger Sohc and a 5 speed manual. Currently, it's sitting at 308,967 miles, and the clutch has all but bit the dust. Right now, taking off on any sort of incline is out of the question without the parking brake half engaged, and even then it's a helluva struggle. So, any of you guys know anything about clutch replacement on these things? I've been questing on the interwebs, and seen lots of different things ranging from pulling the whole engine and transmission (all 150 pounds of it lol) to doing it with both engine and tranny in the car to basically removing the entire front end. So, what do you guys think? All help is appreciated. | |
| | | AllisKidD21 Moderator
| Subject: Re: 1999 Saturn sl1 October 23rd 2018, 1:06 pm | |
| Well being that it's a FWD car, seperating the transaxle from the engine is a bit more difficult. There's a chance that removing the wheel, steering knuckle, strut, lower A-arm, etc on the trans side would allow the trans to slide out enough, but I'm not so sure. It'd definitely be tight working trying to do it that way. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
| Subject: Re: 1999 Saturn sl1 October 23rd 2018, 5:12 pm | |
| personally Id pull the engine and trans as a unit and replace it out of the car, 99 percent sure you can unplug the wiring harness at the engine computer and feed it back out to the engine. ive seen a couple clutch jobs done on fwd in the car and it looked absolutely awful to do, no space, hard to line back up etc. | |
| | | muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: 1999 Saturn sl1 October 23rd 2018, 11:32 pm | |
| Yeah I agree, as much of a pain it is by pulling everything, I think you are going to regret it if you end up working in such a tight space. | |
| Subject: Re: 1999 Saturn sl1 October 31st 2018, 3:09 pm | |
| I had the clutch replaced in my 2002 sl1 at around 100,000 miles. My buddy worked at the shop that did it. I can ask him but his memory ain't the greatest.
EDIT: So I just checked with my mechanic friend and he thinks they unbolted the trans and moved it out of the way. | |
| | | | | 1999 Saturn sl1 | |
| Who is online? | In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
