| Right Angle Gearbox | |
+3MatthewD Crazy_Carl ConfederaSears 7 posters |
ConfederaSears Member
Age : 22 Join date : 2017-05-25 Points : 2806 Posts : 54 Location : Misery/Missouri
| Subject: Right Angle Gearbox May 10th 2018, 1:47 am | |
| So im in need of a right angle gearbox for my next build, i have a honda 2cly liquid cooled engine that im dying to use and a peerless 2300 i still have to go pick up from a friend. Anyhow i want to hook the driveshaft to the gear box then the output shaft use pullies and belts to the 2300, im having a hard time finding a cheap local gearbox so i may just build one myself. Option 2 is make the driveshaft hook on a peerless 700 i have laying around and make a special pulley off the output shaft from the 700. So the question is would the 700 hold up being directly to the honda? Would the gear reduction be to much and it be super slow? It would be pretty neat tho using the 700 has a transfer case kinda. Let me know what you think, any kinda help would is apprreciated! | |
Crazy_Carl Veteran Member
| Subject: Re: Right Angle Gearbox May 10th 2018, 7:06 am | |
| I don't think a 700 would hold up very well with a driveshaft from a 2 cylinder engine hooked to it. How would that work anyway? It has a vertical input shaft. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: Right Angle Gearbox May 10th 2018, 7:56 am | |
| Is the twin cyl engine you want to use horizontal shaft? Because if it is you can just run a belt from it to the 2300 as it has a horizontal input shaft. | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 10:26 am | |
| Hmm, the way I'm picturing this is with the 700 flipped up so the pinion shaft faces the flywheel of the engine with a drive shaft between the two. Then one of the output shafts of the trans will be able to line up with the pulley on the 2300. I'm thinking that if you mounted the Peerless 700 extremely solid and made a brace for the pinion shaft housing, etc, it would work. The reduction shouldn't be a problem with the shaft drive setup because the pinion shaft with esenctially be spinning the same RPM as the engine basically the same as having a 1 to 1 pulley swap. I think it could work, but you just might want to check the rotation of everything first to make sure you arent gonna have 5 reverse speeds and one forward speed, hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Right Angle Gearbox May 10th 2018, 10:35 am | |
| - AllisKidD21 wrote:
- You just might want to check the rotation of everything first to make sure you arent gonna have 5 reverse speeds and one forward speed, hahaha.
LOL, I hadn't thought of that. Your right! | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 8:09 pm | |
| - Crazy_Carl wrote:
- I don't think a 700 would hold up very well with a driveshaft from a 2 cylinder engine hooked to it. How would that work anyway? It has a vertical input shaft.
They can be mounted in any position. Puppetkicker on youtubed used one for a 5 speed go kart with a horizontal engine. | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 8:10 pm | |
| - MatthewD wrote:
- Is the twin cyl engine you want to use horizontal shaft? Because if it is you can just run a belt from it to the 2300 as it has a horizontal input shaft.
Yes horizontal shaft but its in inline 2cyl from my 3813 | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 8:13 pm | |
- Hmm, the way I'm picturing this is with the 700 flipped up so the pinion shaft faces the flywheel of the engine with a drive shaft between the two. Then one of the output shafts of the trans will be able to line up with the pulley on the 2300. I'm thinking that if you mounted the Peerless 700 extremely solid and made a brace for the pinion shaft housing, etc, it would work. The reduction shouldn't be a problem with the shaft drive setup because the pinion shaft with esenctially be spinning the same RPM as the engine basically the same as having a 1 to 1 pulley swap. I think it could work, but you just might want to check the rotation of everything first to make sure you arent gonna have 5 reverse speeds and one forward speed, hahaha.
Thanks for the info allis! i still need to get a few parts together before i start building. | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 8:16 pm | |
| Sounds good! Should be pretty neat. What are you planning on using for a clutch? I assume some sort of friction disk setup? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 8:23 pm | |
- Sounds good! Should be pretty neat. What are you planning on using for a clutch? I assume some sort of friction disk setup?
Not sure how the stock honda one is set up but i may use it. Probably going to have one on the belt set up also. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Right Angle Gearbox May 10th 2018, 9:20 pm | |
| You will still have a reduction through the 700 in high gear, around 8 to 1 when it comes out of the 700. I am sure I am wrong on the ratio but there will be some kind of reduction from the 700 input going to the output. You would have to do the math by counting teeth, then you would have to overdrive the 700 input to compensate in order to have a 1 to 1 from engine to the 2300. Even if you split the overdrive between the 700 and the 2300, the stresses on over driving the parts would probably have alot of belt slippage or breakage. And that would be just having the same speed before and after.
Might be easier and simpler to just have a right angle gearbox that can take the load, and probably cost the same too in the end but be more simpler and more reliable. | |
| Subject: Re: Right Angle Gearbox May 10th 2018, 9:41 pm | |
| - prancstaman wrote:
- You will still have a reduction through the 700 in high gear, around 8 to 1 when it comes out of the 700. I am sure I am wrong on the ratio but there will be some kind of reduction from the 700 input going to the output. You would have to do the math by counting teeth, then you would have to overdrive the 700 input to compensate in order to have a 1 to 1 from engine to the 2300. Even if you split the overdrive between the 700 and the 2300, the stresses on over driving the parts would probably have alot of belt slippage or breakage. And that would be just having the same speed before and after.
Might be easier and simpler to just have a right angle gearbox that can take the load, and probably cost the same too in the end but be more simpler and more reliable. Kinda what i was thinking, ill probably just go with a gearbox and keep the 700 for my sears or dynamark. | |
| Subject: Re: Right Angle Gearbox May 11th 2018, 9:53 am | |
| Maybe I'm missing something here, but why can't you just run the engine direct to the 2300? Not sure why you'd need a RAGB. | |
| Subject: Re: Right Angle Gearbox May 11th 2018, 12:21 pm | |
| I think he wants to mount it online with the frame if that makes sense. It would either be offset or need a jackshaft if he mounted the engine sideways, not to mention really wide | |
| Subject: Re: Right Angle Gearbox May 12th 2018, 12:07 am | |
| @MatthewD Its the 2cly liquid cooled inline engine i should have stated that. Pretty sure it would be odd looking mounting it sideways on the frame. Im wanting to stick with the honda frame and ditch the stock 5 speed, maybe use it another day but for now i want to use a 2300 | |
