 100$ Dation 16HP MTD 990 "Mud Train"
darkside0914
14 posters
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next
RockeyDA
100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Empty
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 1st 2018, 6:27 pm
DAMIT DAMIT DAMIT, ALREADY SHEARD KEYSTOCK ON THE FLY WHEEL ESDFDVDVF. IM SO NOT HAPPY
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 2nd 2018, 8:46 am
ok, i was up till 2am light niht working on it, now curretn problm is i cant get it to run right, took me a while to find out it was the thrttle bouncing on the carb xsetp. might steal the spring from the 12hp and buy a replacement off ebay.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 2nd 2018, 7:55 pm
That's sounds like a nightmare to troubleshoot but good job finding it.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 3rd 2018, 12:13 am
im uploading a clip from a trail ride ile post here befroe i go to bed, but i think im leaking hydro fluid and motor oil. Dfently loosing motor oil. a 5hr ride put me from full on oil to just blow the minimum line.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 3rd 2018, 12:22 am
this websites censorsing is out of hand, i cant post the video link beacase its "watch?v= v e f y n T S F a g U "  i added spaces so you can see the link. if i actualy posed it it comes out like this
[youtube]i'm insecure[/youtube]
Edited for your pleasure. [some words are a bit broad, I have been fixing as they pop up] -MightyRaze
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 3rd 2018, 12:47 am
I added your video and fixed the issue.  I also left your original message text alone.
100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Sig115PROJECTS:
100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Sig214100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Sig314
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 3rd 2018, 10:25 am
Your trans is a Hydro.  I bet it was getting a bit overheated there at the end, maybe also a little moisture in the fluid when it was hot. That could have been the cause of the slowdown and maybe harder to move.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 3rd 2018, 10:39 am
thanks, i apritate it.
SebastianAlbrecht wrote:
the small 16"ers dig into the mud, and the rear tires doesn't seem to have enough traction, they have like a turf tire tread pattern
yeah, thoes 16" tiers suck for steering in mud, and thoes 35" tiers suck for gripping in the mud. long video with more problems coming soon. but this big tractor is a joke compared to dinky.
think i should cut every other tread out like people do to turf savors?
probboly, but i also think i might not have enough fluid in it, on the drive there after i basically left my yard i was going in pulses. when i was heading back, when i stopped at the gas station i noticed oil dripping in the front and back of the tractor, back side seems to be comming from were that hydric line goes to the blade deck, front was coming from the motor, motor went from topped off on oil to just blow the minimum fill line. i think my red RTV crank case gasket failed there.
btw when i got out of that mud hole, (did not think to touch trans) the pump was hot, but not somthing i cold not hold hot.
when i eddit the video you guys will see it as soon as its done, theres even fun stuff like me having the camra rolling while getting partaly run off by the 990.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeNovember 6th 2018, 5:24 am
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 9:09 am
the motor on this is a keystock sheering mashine. this tractor is dead till i find stronger keystock, have stronger key stock made, or just weld the damn fly wheel on as a last resort.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 10:23 am
So what I have done to prevent a shearing was make sure the crank shaft keyway is tight, check the flywheel and make sure there's no slop, then I put a thin layer of in weld on the mating surfaces and torqued that "Female dog "down. Hadn't had any issues till the block blew up.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 11:48 am
I mean, if the flywheel is out of balance (which it will be), it's no mystery that it's gonna shear the key constantly no matter what ya do. What did you torque the flywheel nut to?
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 2:48 pm
it shears when it misfires usealy on a start. its never sheard while running. and torqe? i just use a pipe wrench and bash the handle with a hammer untill it stopps getting tighter. i cant turn it by hand and even get it snug.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 3:09 pm
........Okay.......
We have our problem, and now we have our cause.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 4:56 pm
Your threads are most likely messed up. It should go on smooth until snug.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeDecember 2nd 2018, 7:24 pm
Rockey, that aint the conventional way to tighten a flywheel nut. Lol
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 7th 2019, 1:08 am
ok, this things alive agin, i welded the fly wheel on and i messed with the governor its it has way more speed and power and dose not bogg down any more because the governor properly brings the throttle up under a load.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 9th 2019, 9:39 am
Wonder how long steel welded to cast iron with a chinese welder on an off balance flywheel will last.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 9th 2019, 12:24 pm
i would bet that im done with fly wheel problems for the rest of the motors life unless for some reson i need to take it off. you said i could not weld the fins back on the fly wheel, and not one i have welded on has came back off.
also i played with the govonr setup and that part of it runs GREAT now. i have so much power. at the moment that motor is my best running single and it runs better than it has ever ran since i had it. i dont even have to choke it to start it with the governor working right.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 9th 2019, 12:25 pm
oh, and both the motor and the trans oil leak has slowed down immensely since i started using the thing alot. to the point i have gone 2 weeks and haven't noticed the motor or trans oil level drop.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 10th 2019, 5:17 am
doing some late night dumpster diving with my friend, the trash cart, and the mud train.
100$ Dation 16HP MTD 990 "Mud Train" - Page 5 KlJMliZ
100$ Dation 16HP MTD 990 "Mud Train" - Page 5 CltuGBo
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 12th 2019, 9:08 pm
I cannot stress this enough. The flywheel key is nothing more than an alignment tool. It does not stop the flywheel from turning. It's not supposed to.
The thing stopping the flywheel from turning is the torque on the flywheel nut. If the flywheel nut is not properly torqued, then the flywheel will spin and shear the key.
If you put a steel key on that crank you will tear the keyway out of that crank, and potentially crack the flywheel as well.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 13th 2019, 9:57 am
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 13th 2019, 10:01 am
its been dealt with and wont be a problem any more. the motors never ran better. i do on the other hand need to see if i can find a new belt for the startor. or remove the starter and make it were i can pull start, witch i would like more. well id really like both.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 5 Icon_minitimeJanuary 13th 2019, 10:07 am
It won't be a problem until the welds break because you can't weld cast iron.
Page 5 of 11Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next
» 16hp Solenoid
» 16hp Kohler magnum
» Can i put the carb from the 16hp on my 11.5 for more power?
» 16hp twin carb?
» 1980 Murray 16hp offroader
