| Talk About Anything Thread V3 | |
+14muckmudd Double W Cross Ranch CraftsmanQuad19 itsBella Doug darkside0914 muddstir TheBeal prancstaman Osco MatthewD RichieRichOverdrive biggasmowers AllisKidD21 18 posters |
| Subject: Re: Talk About Anything Thread V3 July 30th 2018, 6:32 pm | |
| Thanks Matt! Yeah I do as well, some pretty cool old stuff made back in the day. It's a K160 which I believe is rated for 6.6hp. Same engine Bolens put on the Ride-O-Matic, which is very similar to this rig but it's a four wheel riding tractor. | |
Crazy_Carl Veteran Member
| Subject: Re: Talk About Anything Thread V3 July 30th 2018, 7:17 pm | |
- PSA, we're 27 days away from the 30th anniversary of the greatest album of all time.
Master of Puppets? | |
Age : 22 Join date : 2016-10-29 Points : 7212 Posts : 4014 Location : Lewisburg, KY
2020 Build-Off Top 3 Winner
Age : 48 Join date : 2018-05-05 Points : 2983 Posts : 518 Location : S. Illinois
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 4:12 am | |
| hmm now this is a stumper for me, briggs ohv, not sure of the hp but i'd say around 17.5 based on the tractor it's on, a 2010 or so yardman with a 42in deck, it's getting good fire, compression, fuel, the valves are in need of a little adjustment but not bad, and it won't start, in fact it actually acts like it has no compression when cranking, it cranks really fast, I don't think it's a valve issue because of the fact it has good compression, the same with the decompression valve, I was told the briggs ohvs have one, as I said i'm stumped on this one, any ideas on what it might be would be appreciated. | |
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 1:03 pm | |
| Yeah it actually does seems like the valve lash needs to be adjusted. If that's not the cause of it maybe check to see if the flyhweel key hasn't sheared or something. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Doug Site Owner
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 4:48 pm | |
Master of Puppets?
- ...And Justice For All.
But Metallica isnt even good I second!!! I hate heavy metal. | |
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 6:49 pm | |
| - CraftsmanQuad19 wrote:
- Valves need adjustment. I’ve seen that multiple times on Briggs OHVs
as far as I know it won't start on starting fluid, the upper valve, sorry I don't know which is intake and which is exhaust, is a little loose, but doesn't seem so loose it would affect it much, the lower valve could be to tight but i'm not totally sure until I find my feeler gauge, the owner said he checked the flywheel key and it was fine | |
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 7:51 pm | |
- He probably listens to black sabbath secretly lol
Nope! I just listen to vintage country and bluegrass. | |
| Subject: Re: Talk About Anything Thread V3 July 31st 2018, 7:52 pm | |
| The exhaust valve is the one that the compression release is on. Just a little too snug and you lose your compression. Fiddle with them some. I got the last one I did totally by feel | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: Talk About Anything Thread V3 August 7th 2018, 2:38 pm | |
| Nice little mower. I like them 20" rears. You'll need to put a bumper or something to protect that trans at the rear. You should make a thread for this machine. | |
| Subject: Re: Talk About Anything Thread V3 August 7th 2018, 3:21 pm | |
| - MatthewD wrote:
- Nice little mower. I like them 20" rears. You'll need to put a bumper or something to protect that trans at the rear. You should make a thread for this machine.
We will mod the Bagger mount thing to protect MST I have so much threads running, IDK how I should have enough time to take care of it too. | |
| Subject: Re: Talk About Anything Thread V3 August 8th 2018, 10:08 pm | |
| - Crazy_Carl wrote:
- It's nice to have front tires on it to roll it to the junk yard.
Once he sent it hard, he can roll it to the junk yard. Probably in 5 Years or so | |
| Subject: Re: Talk About Anything Thread V3 August 9th 2018, 6:05 pm | |
- The exhaust valve is the one that the compression release is on. Just a little too snug and you lose your compression. Fiddle with them some. I got the last one I did totally by feel
we adjusted and readjusted the valves, contacted the owner and he decided to put another engine on the chassis, so we took it back to his place, but it'll probably end up being used for parts anyway, the guy sort of fixes used mowers and resells them, I say sort of fixes them because he does what he needs to in order to get them running and mowing and sold to whomever is willing to buy them, mostly he just sells used parts though. | |
Age : 49 Join date : 2016-09-06 Points : 15660 Posts : 10979 Location : Oklahoma
| Subject: Re: Talk About Anything Thread V3 August 10th 2018, 1:05 am | |
| - MightyRaze wrote:
- Nice to be home. Now to crack the whip on you guys. LOL
Hey we din' do nuffin!! Welcome back Mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
