 Peerless 820 Shifting Issue
Glen4X4
8 posters
Go to page : Previous  1, 2
Peerless 820 Shifting Issue - Page 2 Empty
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 28th 2018, 4:13 pm
Have you checked the condition of your shift keys? Maybe there's a burr there or they're chowdered up.
Glen4X4
Glen4X4
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 9:57 pm
I put’er back under the tractor tonight. I didn’t drive it far since it’s dark and didn’t want to get hit. It seemed to shift fine now, but it’s too early to tell for sure.
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 10:34 pm
Hopefully you got'er fixed. It already sounds better.
Peerless 820 Shifting Issue - Page 2 Sig115PROJECTS:
Peerless 820 Shifting Issue - Page 2 Sig214Peerless 820 Shifting Issue - Page 2 Sig314
Glen4X4
Glen4X4
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 10:37 pm
Yeah buddy, the barbed fitting, is that something that can be found at a hardware store? If so then I can take the red cap in to get the right size and threads. I just looked online but idk what size I need and stuff like that I like to buy in person.
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 10:50 pm
I am not sure of the threads, but take the red cap with you if threaded and go to the hardware store over by the pipe fittings and such.
EDIT, google search gave me this.
Tecumseh 792074
Plug, Hex hd., 9/16-18 thread (Peerless part number)
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 11:21 pm
MightyRaze wrote:
Copying this info to the Tech forum.  I was looking there but had not found anything.  I can also confirm the same fitting works in an MST 206 drain plug hole as well.  Your suggestion to me long ago.  Smile
EDITED- Good catch. I forgot to include the MST, which I have also done it on. It's late, and I'm tired as heck.
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 11:22 pm
Well crud it was suppose to copy.  Let me fix. I think I had a forum hiccup. please stand by
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 11:26 pm
It would appear I do not have permissions in tech forums to bring those posts back.  So here are the quotes.  I sincerely apologize for mixing this up.
Doc Sprocket wrote:
Barbed fitting- Get a 1/4" NPT pipe to 1/4" Hose fitting. They're usually brass. Chuck it in a vise and cut the last 3 threads off. Teflon tape it well, and screw it in. Why cut it? If you don't, it will bottom out and hit the shift fan.
I've been using this method for years.
Doc Sprocket wrote:
MightyRaze wrote:
Glad you popped in Doc, I knew you had done it on this model before.  I was just about to tag you!
Go figure! LOL-
The above applies to ALL Peerless pancake style aluminum transmissions and transaxles. 700, 800 (Incl 820), 900, and MST. I've done it on them all.
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 11:32 pm
Just a word on the MST- I'm struggling like hell to remember here-
I seem to remember the drain/filler hole not being threaded, and me having to thread it. Maybe I'm wrong, and I'm tired- but in the case of all other models, the fitting goes in the neutral safety switch hole.
PostSubject: Re: Peerless 820 Shifting Issue   Peerless 820 Shifting Issue - Page 2 Icon_minitimeMarch 29th 2018, 11:34 pm
That is correct, You have to thread it. I was able to self tap my barb fitting.
» Transaxle Shifting Problems
» Spicer 6 speed shifting issues
» servimg issue?
» Youtube Issue?
» Starting issue
