| Talk About Anything Thread V2 | |
+10mr.modified muckmudd biggasmowers AllisKidD21 Crazy_Carl CraftsmanQuad19 Doug TheBeal Double W Cross Ranch MightyRaze 14 posters |
biggasmowers Veteran Member
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3559 Posts : 825 Location : In the shop
Age : 24 Join date : 2016-12-30 Points : 4928 Posts : 1944 Location : Kansas
| Subject: Re: Talk About Anything Thread V2 Fri 02 Mar 2018, 9:04 pm | |
| If your referring to the Death trap, yes it is going to have a large tensioner with lots of movement and a strong spring. I am considering putting in a jackshaft to take off some strain from the output gear on the foote. | |
Age : 49 Join date : 2016-09-06 Points : 15662 Posts : 10980 Location : Oklahoma
Age : 20 Join date : 2017-06-09 Points : 5490 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Talk About Anything Thread V2 Fri 02 Mar 2018, 10:03 pm | |
| Okay, so the John Deere is still available. Gonna go pick it up tomorrow. I'll give ya'll more info on the tractor itself when I get her. | |
Age : 25 Join date : 2016-07-10 Points : 8585 Posts : 5190 Location : Ontario Canada
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 11:08 am | |
| Sweet deal! How much did ya get it all for? Do all three engines turn over? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 1:00 pm | |
| Awesome man ! I want pics from all angles and lots of drive train / under belly pics. Whatcha going to name it? How about buck ? Buck Deere lol | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 1:02 pm | |
| 45 for all. Engines turn over. The 2 dont have carbs , but have good compression. The one on is complete, but has no compression. | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 1:07 pm | |
| That's a good deal. Judging by the cylinder head the one standing up is a smaller model like a K161 or a K181, can't really tell what the one laying down is. Also regarding the compression issue, if it's a K241 or bigger it may have ACR which mean there wont be any compression until about 600 RPM's. If you spin it backwards and it has compression it means it's just the ACR doing it's job. If it has no compression at all in either directions I'd look in the ports to see if a valve is maybe stuck open. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 1:08 pm | |
| Nice! Then you can just swap externals and have a good running engine with another backup block with internals and another with compression in case you ever wear out the other one. Good deal for 45 bucks . Does it have a vari drive or is it direct ? Its geared right? | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5715 Posts : 1402 Location : Central PA
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 1:58 pm | |
| I need to get my mowers . I habe a trailer lined up , all I need is my friend to get off work to help me load them. | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 2:00 pm | |
| Also W there are a few good videos and pictures on the web of the variable speed on those tractors and apparently they sometimes need adjustment. Just in case you find yours not working properly, it may just need adjustment. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 2:04 pm | |
| That thing is sick. Even if it has no carb it probably needed a new one anyways because of how old it is. | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 2:07 pm | |
| Sounds like a cool idea for a drive system , with all of those speed adjustment it says top speed is 6.5 mph stock. Little pulley swap and it could hit 17 mph easy. | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 2:53 pm | |
| Yeah so it is geared and does have vari drive. The trans seems fine, vari drive seems to work. The whole thing is 3/8 inch steel and cast iron, must weigh 950 LBS, lol. The engine that's in it has no compression and spins over way to easy and has a dragging noise inside. When I got her home I put a screw driver in the spark plug hole and turned it over...and the valves and piston did not move. I was wondering about that when I was looking at it, but I got it anyway. The other 2 have awesome compression, so I can definitely make 1 good engine out of the mix. The clutch works well. I don't see any issues with it except for the engine. Pics later, it's still in the truck lol. Took us a 2000 pound winch to get it on it. Buck sounds like a neat name haha. Plans are a diff lock, ags on the front and rear, pulley swap, probably want 20 mph. Should be a fun build, will start a build thread when I have time and will tear into her to get her running! Gonna kinda restore it, want it to look pristine like it did 50 years ago. UPDATE: Got a build thread! https://www.atltf.com/t5687-25-1968-john-deere-110#84956 | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 6:28 pm | |
| Nice, can never have too may parts tractors, haha. What kinda transaxle is in the Craftsman? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 6:30 pm | |
| Spicer, it's a 6 speed and I plan on making it a mowing mower with an off road touch if I get a deck for it. | |
| Subject: Re: Talk About Anything Thread V2 Sat 03 Mar 2018, 6:35 pm | |
| Ah, I see. Sounds kinda neat. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
