| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
TheBeal Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 19th 2018, 9:26 pm | |
| No, just a little rework, but nothing I need to cut and redo at this time.
No it has been a day of agitation. No progress made:
While trying to figure out a good spot for the third link mount to the frame I realized I was struggling and need to review my breakdown pictures.
Got on my computer and realized I lost all my breakdown pictures when my computer and backup drive cratered when they got zapped with static electricity.
Due to lack of breakdown pix, I decided to try a partial reassembly of the tractor and steering hardware. I quickly realized the lack of room underneath the tractor.
I also noticed I had no room for steering where I have my outer links attached to the frame.
I also cannot remember how the brake runs through all the stuff under the frame. I think it goes through the back foot board rest. It's hanging up. That massive brake works really well.
I also think I dropped every nut bolt and tool on the garage floor. Overall a very frustrating day.
On a positive note, I did figure out how to redo the outer links and use the existing mounts to assist with the inner link.
Also, I have about half an inch between the foot board and the tire. YIKES! I think when all is said and done I may have about 3/4 of an inch.
Plan at this point is to run a 5/8 rod through the current mount point for outer links for the center link, while at the same time beefing up those mounts and lower new outer link mounts. Then run a center brace for that 5/8 rod so it does not bend. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
Crazy_Carl Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
Dave.MTD Member
Age : 24 Join date : 2017-01-11 Points : 2907 Posts : 37 Location : Hamilton, Ontario
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 21st 2018, 9:10 pm | |
| Yeah we still have power at this time. Much of the power in my area is underground in the residential area where most of the trees are. The main lines, they keep them cleared back pretty good.
It came with the belt twist, I personally have had no issues with belt twists. Honestly I don't want to drop a couple hundred in a RAGB. And if I did, I would have to remove the fender brake as it runs across the opening in the frame for the belt. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 22nd 2018, 10:21 am | |
| I will sell you one that is in very good condition with no worm gear slop for 40 bucks plus shipping . 7/8" shafts with aluminum housing. Off of a Toro. I can pot some pics if your interested | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 25th 2018, 12:18 am | |
| I have done absolutely nothing lately. Been too many other projects to do. That and ice storm stuff. I have some chainsawing to do. Lost about 5 tree limbs. Not bad considering we had about 0.4 inches of ice. I need to also go get some parts to continue the build. Another project I had to do was, during the ice storm the garage door was frozen shut and broke the opener. Got the new one installed today. It is super nice and super quiet. It even has a battery backup on it. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 25th 2018, 10:56 pm | |
| I did get some parts today.. Looks like I need a few more. Did I mention things are a bit tight under the frame? Lots of factory braces everywhere. I may need to re-engineer some of those. We will see. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 26th 2018, 9:50 am | |
| had about the same amount of ice over two storms last week, and now all of our roads are muddy and tore up from traffic . Sadly i dont have a running mower right now but i plan to get the craftsman running again after i fix the rear belt keeper that bent and keeps throwing the belt off and it needs a new idler on the clutch. Did cut some fire wood and found out i needed to clean the carb as it was bogging down way to easy , after some carb tlc it runs quite well again. NEW garage door openers are great aren't they?
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 26th 2018, 6:32 pm | |
| So, I could not sleep last night. I was having 3 link nightmares. I did a lot of thinking today with half the day off from work. I think I will cut back off a couple brackets on my front axle and try plan B. I got out some of my square tube and did some measuring and more thinking. Hush Allis... you know what I am thinking. | |
Dave.MTD Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 26th 2018, 6:56 pm | |
| Ah, do I see a 1 link coming together here mighty? Haha, that'd be cool to see on ol' Kal! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
