| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 3rd 2018, 10:53 pm | |
| Looks great mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 4th 2018, 1:47 pm | |
| Trust me, I'm not pulling a copy job. I have no Idea what year the engine is. It was missing the tin with the serno, type, etc. If I was a guessing man, I would say early 80's? 83ish maybe? My fan came from the original engine from the 90 Craftsman GT I have. I plan on using the old drive pulley too. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7778 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 7th 2018, 4:24 pm | |
| Input pulley seal still dripping oil. Grr... It's so high, I'm not worried about running out of oil. I'll let it drip down and see if it stops. The amount I put in was a bit more than it had even though it was the spec amount. | |
Dave.MTD Member
Age : 24 Join date : 2017-01-11 Points : 2906 Posts : 37 Location : Hamilton, Ontario
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 7th 2018, 11:41 pm | |
| Those rear tires look great mighty! Especially with the the fronts mocked up too. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 8th 2018, 7:22 am | |
| I have a couple of ideas mighty. Is that your final ride height in the front? I figured that you'd want it higher like that to give yourself room for front suspension. If that's the case I would do a little bit of lift in the rear to level the frame out.
Secondly, that transaxle has a horizontal input shaft. I know you already have your motor picked out but you'd get some serious points in my book if you modified the driveline and converted to a horizontal shaft engine. It would be pretty easy since you already have the frame stripped down. Once you have the belt drive figured out you can just build the body work around it. I haven't seen a conversion like this yet so it would be pretty unqiue. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 8th 2018, 10:39 am | |
| I did find the right angle gearbox finally for "some versions" of the machine (cheapest $180). Like I mentioned before, mine has a secondary hand brake feature that makes having the gearbox pointless as it is run across the belt hole in the frame.
Also, I am not concerned with the nose up a bit. With this style Murray it would look pretty mean. But I do feel it will be a bit more level once the Opposed is on there. I'm only going for a few inches of flex to take out some of the "bumps". Not building a fully articulated machine to rock climb.
As for a horizontal engine? It would look totally wrong with they style of hood I have. Also, I would have to cut quite a large slit down my frame to accommodate the belt. I would rather not mess with the integrity of the frame. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 8th 2018, 12:55 pm | |
| I agree with leaving the vertical shaft engine in, especially since the hood already has cut outs for the cylinder heads of the opposed. Also, for what's it's worth I think a little bit of nose height makes some machines look more intimidating. Not sure why but I've always liked that look, hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4055 Posts : 870 Location : Phillydelphia
