| Murray CCT [pre-build] | |
+5CraftsmanQuad19 RichieRichOverdrive prancstaman AllisKidD21 MightyRaze 9 posters |
biggasmowers Veteran Member
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 9th 2018, 10:31 pm | |
| Ooo.. good catch.. It's on the other side of the garage. I'll put it front center. CQ, As I could easily do that, I'm pretty ethical and would not do that. | |
![biggasmowers](https://2img.net/u/2812/37/66/46/avatars/2889-58.jpg)
Age : 24 Join date : 2016-12-30 Points : 4856 Posts : 1944 Location : Kansas
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 10th 2018, 10:16 am | |
| I like that. " pretty ethical" lol thats great . hood is sweet, looks like the one on lil red | |
Crazy_Carl Veteran Member
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 10th 2018, 6:01 pm | |
| Look out AllisKidD21 and biggasmowers! Looks like someone else is cooking up some sweet off road suspension plans. mightyraze, I know you're using those coil overs. Are you going to use those upper and lower control arms too? A mower with independent front suspension would be quite the contender in the contest. | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 10th 2018, 10:18 pm | |
| Independent is great for a trail bombing rig. The Twin I-Beam on my little Ford soaks up bumps like a dream, much better than a solid axle setup. But a solid axle is better for flexing and crawling.
![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 10th 2018, 11:05 pm | |
| Those are some beefy coil overs for sure! the weight limit on those must be pretty high, so could be a stiff ride | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 18th 2018, 1:32 pm | |
| So.... I seen another 2300 peerless on FB, today and looking at it gave me the realization that I could turn my hubs around to get more rear stance if I wanted. ![Murray CCT [pre-build] - Page 6 11251710](https://i.servimg.com/u/f62/19/56/75/89/11251710.jpg) | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 18th 2018, 2:01 pm | |
| That's a good idea Mighty. It looks like you could gain another 4 inches of track width doing that. | |
![RichieRichOverdrive](https://2img.net/u/2812/37/66/46/avatars/2731-86.jpg)
Age : 22 Join date : 2016-10-29 Points : 7020 Posts : 3898 Location : Lewisburg, KY
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 18th 2018, 8:28 pm | |
| You should definitely try that.
Even though I haven't murdered a rim in a while I still wish I had some hubs...
Actually it just occurred to me that if I just get some atv rims I could just make hubs in machine tool. Hmmmmm... | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 20th 2018, 8:20 pm | |
| Rims almost done.. Also, I ran a test piece for my color for the build and that turned out great. I am pretty much ready for this thing. I do need a couple pulleys and a few pieces of metal tube. Oh yeah! ![Murray CCT [pre-build] - Page 6 01201810](https://i.servimg.com/u/f62/19/56/75/89/01201810.jpg) | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 21st 2018, 8:17 am | |
| Sweet. Have you ever used onlinemetals.com? They have pretty reasonable prices and you can buy small pieces too. I buy stainless pieces I need for work from there a lot because it's so convenient. | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 21st 2018, 6:14 pm | |
| OK, did some final prep for the build-off. Such a beautiful day today here. 72* Fixed my footrest bracket. Starting to get a little handy with the ole welder. ![Murray CCT [pre-build] - Page 6 01211811](https://i.servimg.com/u/f62/19/56/75/89/01211811.jpg) ![Murray CCT [pre-build] - Page 6 01211812](https://i.servimg.com/u/f62/19/56/75/89/01211812.jpg) Also mounted those Badlands... Good gosh they are HUGE! Here is some comparison shots. Regular 12" garden tractor wheel. Then Red's massive rear tires look TINY next to them. ![Murray CCT [pre-build] - Page 6 01211813](https://i.servimg.com/u/f62/19/56/75/89/01211813.jpg) ![Murray CCT [pre-build] - Page 6 01211810](https://i.servimg.com/u/f62/19/56/75/89/01211810.jpg) ![Murray CCT [pre-build] - Page 6 01211814](https://i.servimg.com/u/f62/19/56/75/89/01211814.jpg) Only other thing I can think of is getting those other tires off the wheeler frame for this build. So ready! | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 21st 2018, 7:28 pm | |
| Got the quad tires off and uh..... they are in worse shape than I though. Hmm..... I will need to come up with a replacement. They were dry checked pretty bad. | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 23rd 2018, 2:27 pm | |
| Its a wide body front axle, eww. oh well should work i guess if you dont mind the plastic steering spindle bushings | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 23rd 2018, 2:36 pm | |
| It actually came off one of these guys. ![Murray CCT [pre-build] - Page 6 Murray_12hp_slash30](https://upload.wikimedia.org/wikipedia/commons/3/3e/Murray_12hp_slash30.JPG) (Image sourced from Google search) I'll see if I can find the actual later. | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 23rd 2018, 2:41 pm | |
| oops sorry i meant pan frame . which is worse than a wide body axle lol | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 23rd 2018, 2:58 pm | |
| LOL, i do plan on "beefing" or changing it up. If I even use it at all. ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) | |
![Murray CCT [pre-build] - Page 6 Empty](https://2img.net/i/empty.gif) | Subject: Re: Murray CCT [pre-build] January 26th 2018, 11:37 pm | |
| Wow that looks beefier than I pictured. Should be a nice setup! What kinda ratio are we talking about mighty? ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
