| My 99 murray build. | |
+8Khal03 Angchor 1997 Murray craftsmancole MurryMaddnes Ariens YT11 redlinemotorsportts CornShuck4CE 12 posters |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4214 Posts : 337 Location : Woodville Al
| Subject: My 99 murray build. April 26th 2014, 11:50 am | |
| Alright i figured i would make my own post of my mower. My mower started life as a organ doner for my grass cutter. It was in rough shape. It had a 18 horse oppy and a peerless mst 206. So i wonted to build it into a offroad mower. Befor this i had the same mower sept it was a hydro. Had 22 inch tires on rear and thats it till i got mower now. This is what it looked like. When i first started documenting my build I already had some mods done the first was pulleys foot throttle then brakes. I did the foot to run off governer but still use the hand throttle on governer. To do this i drilled a hole in governer rod put a bolt in it with a 1/8 hole it run cable through bolt with a cable lock from a bike to hold a spring to cable. Then built a cable holder to hold cable at governer rod. with a bike brake lever I did a custum pulley setup for clutch. 6 inch front and 5 inch rear. No pix. The brake is a custom hand brake made frome deck lift components ans linkeges. One of the next thing was exaust. My brother owns a hydrolic hose bisness. And he has a tubin binder so i fabed up a flang and custom bent a piece of pipe to go under the footboard with a TSC muffler and turn down to the ground. But it wasent to last and i did this 3 inch tip with muffler inside it. Next it was on to wireing push button start and so on. The silanoid has been raised up to just under the steering wheel. Igot the hood from a friend who was tryin to build a fast mower motor (16.5 hp B&S high performance OHV) come from same mower. Cold air intake/snorkle made of 1-1/2 pvc with a china atv filter. The blower cover is of a flathead. I like the old ones better. Plus its what i needed for the shock tower support to work. later found a murray GT organ doner witch is where the 820 come from. The best mod iv done is the 4 link front suspension. Here is a link to that. https://www.atltf.com/t3709-4-link-murray-front-suspintion and steering chang from dual tierod to single with drawbar. just used spindels from an old murray. Just had to modafy the tierod and twist and make the drawbar longer. Also put tierod end on the ends. Works good but i have plans to change it. I have done lots of other lil things here and there like. Skid plate Non slip foot boards made from the inside tube of a washing machin. Hand thottle and choke lever. Closed off the deck lift hole. Pullstart. Removable hood. Pull thease pins out of bumper. Its got 26-11x12 tires on rear and 18-9.5x8 on front. And this is where its at today Im sure there is more but thats why i started this. | |
Age : 27 Join date : 2013-03-18 Points : 7461 Posts : 3131 Location : raleigh nc
| Subject: Re: My 99 murray build. April 26th 2014, 12:56 pm | |
| Man that thing is beef, I love the belly pan and skid. Lots of sweet mods man! Is the axle locked? | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 26th 2014, 1:13 pm | |
| Not yet. Iv got the stuff to do it. Im doin a spider gear lock. I really dont wont to weld. But its in the proses
Age : 27 Join date : 2012-10-31 Points : 5142 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: My 99 murray build. April 26th 2014, 2:21 pm | |
| I have a Q: how did you do the suspention on the front, and how much to do it? | |
CornShuck4CE Member
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 26th 2014, 11:21 pm | |
| Ight yall got motivated today. Dun some work on it today. Started painting it. Had bought a pad for my grinder to take off paint. I got the hood finished so her is a sneek peek Befor After So i decided to tear it down and do some work. This took me about 15 min. . Fixin to do alot of work to it i recon. Gettin it ready for a tracter show june 8th. | |
CornShuck4CE Member
MurryMaddnes Member
Age : 38 Join date : 2014-03-24 Points : 3913 Posts : 32 Location : Green Bay Wisconsin
| Subject: Re: My 99 murray build. April 29th 2014, 10:28 pm | |
| Me like lol great idea that paint job looks sweet if you are in fact leaving the metal bare and clear coating it. | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 29th 2014, 10:31 pm | |
| O yea this bad boy has like 7 coats. Its finished. This took a lot of work to get all the paint off. | |
Age : 25 Join date : 2013-04-05 Points : 4940 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: My 99 murray build. April 30th 2014, 10:23 am | |
| It looks nice, I've always wanted one of those style widebodys | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 30th 2014, 10:28 am | |
| I preshat it. Ive had bout 5 diff ones. I love thease models | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5424 Posts : 1311 Location : NW USA
| Subject: Re: My 99 murray build. April 30th 2014, 1:52 pm | |
| say where did you get the bigger gas tank? now that my mower has a twin i need one. | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 30th 2014, 3:45 pm | |
| Thay come in alot of the murray widebody LT. with the big hood. The one withe the hood skirts on the side of dash. Its 2.8 gallons i run a tank seems like forever. But my oppy on my grass cutter sucks er on down. | |
| Subject: Re: My 99 murray build. April 30th 2014, 4:10 pm | |
| ok mine has the big hood but it had a single, so it had the smaller tank i guess. mine is 1.4 gal | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. April 30th 2014, 4:28 pm | |
| My off road mower was a single. 16.5 but it had the big tank. They may have been a special model with them. | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. May 2nd 2014, 8:14 am | |
| Ight boys got lil more dun on er the last few days. Got er painted, locked the 820 and redone shift linkeg. Works great ill upload some pix when it all back together. | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. May 2nd 2014, 9:32 pm | |
| Got er pit back together today made so upgrades to the brake linkeg and shift linkeges works much better now. Ill get som pix in a few days. Her is it put together. What you fellas think. So far i love it. The next task is a foot pedal. Not this bike brake handle. And paint wheels. | |
| Subject: Re: My 99 murray build. May 2nd 2014, 10:17 pm | |
| That bare metal is stright up awesome! How tough is it with the clear coat and all? | |
CornShuck4CE Member
| Subject: Re: My 99 murray build. May 3rd 2014, 9:59 am | |
| It will be ok i used enamal paint so its pritty hard. I also waxed it so it stays shiny. Water just beads up and rolls off | |
CornShuck4CE Member
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4397 Posts : 491 Location : Index, Washington
Khal03 Member
Join date : 2014-04-29 Points : 3877 Posts : 36 Location : Iowa
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7296 Posts : 2914 Location : Ontario Canada
| Subject: Re: My 99 murray build. May 7th 2014, 7:07 am | |
| Good job on the pedal. You have the two elements that make a meh-pedal into a good one. A return spring, and a stop. Much better! | |
