| Murray CCT [pre-build] | |
+5CraftsmanQuad19 RichieRichOverdrive prancstaman AllisKidD21 MightyRaze 9 posters |
Age : 22 Join date : 2016-10-29 Points : 7224 Posts : 4021 Location : Lewisburg, KY
| Subject: Re: Murray CCT [pre-build] November 20th 2017, 12:19 am | |
| Ah ok. That's sorta weird, only place I've seen so small a key on a big shaft is the woodruff key holding the crank gear on oppys(among other engines I'm sure). | |
| Subject: Re: Murray CCT [pre-build] November 20th 2017, 6:18 pm | |
| Here are the brake pads. Pretty large! In other news, it appears I lost my snap ring for the brake.
Last edited by mightyraze on November 20th 2017, 7:22 pm; edited 1 time in total | |
| Subject: Re: Murray CCT [pre-build] November 20th 2017, 7:18 pm | |
| Those are some pretty beefy pads, I'm kinda jealous lol. You should pick up a snapring kit, I'm sure it'll have one or two that'll fit that shaft. | |
| Subject: Re: Murray CCT [pre-build] November 20th 2017, 7:24 pm | |
| Wow those look like automotive style pads! You could even cut a slot down the middle (short way) like car brake pads have for some cooling action. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray CCT [pre-build] November 25th 2017, 9:20 pm | |
| All buttoned up, Torqued to 9 foot lbs. Manual says 8-10, I figured 9 was a good number. New mounting bolts. All it needs is 64oz 80w-90 and remounted to the frame. But that will require a frame clean up and repaint. I would break it down to just the subframe, but I am afraid to encroach upon that 50% mark for next year's contest! Fozzy locked, and pulley swapped from a 7 inch to 4.5 inch. | |
| Subject: Re: Murray CCT [pre-build] November 27th 2017, 9:06 am | |
| I just realized, I could disassemble the whole darn thing and still be under 50%. Looks like this may be a bit Pricey Build. Looks like I need all new idlers (3 pulleys). 2 for the double pulley clutch it already has and one for the belt twist pulley, it also already has. I was wanting to find one of the 90 degree boxes that came on some of these, but I have quickly realized 2 things since tearing into the tractor.
1, they are very expensive and I will probably stick to the belt twist. 2, those with the gear box do not have the fender brake lever that runs across the belt hole for the gearbox.
I think I will go ahead and pull the dash and front axle off and wash up the sub-frame. Nothing more than that.
Also, one oddity, the hitch plate on the rear was put on with 6 bolts, but then welded to the frame? Weird stuff. Also, lots of rivets in this thing. I also found 2 cracks in the metal on the rear fender clip that will need fixed. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Murray CCT [pre-build] November 27th 2017, 9:22 am | |
| Mine was the same way with the rear. Didn't understand why they bolted it and then welded it. I just cut it off and ground flush. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Murray CCT [pre-build] November 28th 2017, 7:05 pm | |
| All right!, I figured out my brake install issue on the peerless 2300. Turns out I was missing 2 parts and had 1 extra bolt that did not belong. I was missing a nut and a sleeve. Sleeve was an easy fix by creating a new one and it was just a standard 3/8 nut. | |
| Subject: Re: Murray CCT [pre-build] November 28th 2017, 7:07 pm | |
| Looks a lot better all painted up mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray CCT [pre-build] November 28th 2017, 7:26 pm | |
| That brake setup looks cool! Never seen anything like that. It's cool that it's that old and doesn't have band brakes. | |
| Subject: Re: Murray CCT [pre-build] November 28th 2017, 7:58 pm | |
| Just need to make 2 changes. A new belt guide and add a small pulley to handle the lower pulley so I don't throw belts. All that can be done on the pulley side mounting plate. | |
| Subject: Re: Murray CCT [pre-build] December 2nd 2017, 1:18 am | |
| Preparing my list of parts. I think I need to put this little v-idler here to keep my belt alignment with my clutch? | |
| Subject: Re: Murray CCT [pre-build] December 3rd 2017, 11:22 pm | |
| Frame is cleaned up and prep'd for build. Contemplating just going ahead and building this thing over the winter for it to be ready to ride and have fun this spring? | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5335 Posts : 2561 Location : Rochester, New York
| Subject: Re: Murray CCT [pre-build] December 4th 2017, 5:58 am | |
| nah I think you save it for the 2018 build off and finish it early so you have more time to ride it before next winter. | |
| Subject: Re: Murray CCT [pre-build] December 4th 2017, 6:02 pm | |
| - Crazy_Carl wrote:
- nah I think you save it for the 2018 build off and finish it early so you have more time to ride it before next winter.
I agree with Carl. If you don't do it for the buildoff me and Allis are gonna nag you til you build something for the buildoff | |
| Subject: Re: Murray CCT [pre-build] December 4th 2017, 6:06 pm | |
I agree with Carl. If you don't do it for the buildoff me and Allis are gonna nag you til you build something for the buildoff I'm up to the task. Hahaha "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray CCT [pre-build] December 4th 2017, 7:49 pm | |
| LOL, looking at my schedule for this month and half of next, I really do not see me doing much more to this thing in that time. So doing this for the build-off is very do-able (99% probable ). I do have that 3rd idler V-Pulley mounted and a belt guide on the transaxle brace done. The transaxle is ready to be bolted back to the frame which I may do sometime soon with an extra set of 12's I have in the shed. And that is all that will be done. I was contemplating a different front axle, but the one that was on it from an old craftsman is pretty strong even though it looks weak. Maybe some bracing in the future. But that will be in the build-off. | |
| Subject: Re: Murray CCT [pre-build] December 4th 2017, 11:38 pm | |
| Trans is attached to the frame (space saving and I need my roller table back), donor tires on until I get the original wheels redone and new tires mounted. Keeping the original tires over the donors because the offset on the original wheels put the tires wider than the donors. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4932 Posts : 1944 Location : Kansas
| Subject: Re: Murray CCT [pre-build] December 5th 2017, 10:32 am | |
| Where do you get parts for the older 2300's ? I had a very old 2300a from the 1960's or some similar model and could not find any parts for it . it was solid cast iron case but had been sitting for about 14 years and was half full of water so the bearings were all rusted out and diff was stuck along with 3 gears that were missing teeth . Ended up trashing it cause couldn't get parts or the left axle out of case to take dif out
