| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
| Subject: Re: Craftsman GT3000 "MUTT" June 10th 2018, 9:18 pm | |
| Put a welch plug in, there wasnt one before Made a new choke linkage. This older carb is a bit different than a typical 3 screw, a bit smaller i think, and the port you'd drill for an external fuel pump isn't there. The old linkage was a bit long and made the arm go too far. It was usable but i didnt like it. Well cleaning the carb didnt help. She ran for a bit then died out. Pulled her over a bit more and nothing happened so i pulled the plugs. Bottom cylinder was wet and the top was dry. She still has spark on both plugs when i pull them out. I think I'll try switching them, and if that doesn't change anything I'll try a different coil. | |
Age : 22 Join date : 2016-10-29 Points : 7209 Posts : 4013 Location : Lewisburg, KY
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 11th 2018, 1:04 am | |
| Put the coil on off the old 20hp. She seems to run great now. Got my fingers crossed, throwing her back together now lol | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 11th 2018, 6:39 pm | |
| The coil and carb cleaning have definitely helped, but I've come the conclusion that the combination of the snorkel and the new exhaust effects the mixture too much to fix it with an idle adjustment. Went back to the old air box. I'll have to figure out something else for a snorkel. Snorkel wasnt really necessary anyways, i should worry about waterproofing the ignition first. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4925 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman GT3000 "MUTT" June 11th 2018, 8:28 pm | |
| My problem is with it running fat. The snorkel acted like a choke, you can smell it in the exhaust. Oh, and she's still not running right. Tries stalling when i step on the gas. Gonna try taking the exhaust extension off tomorrow...maybe that's it Actually i mean it ran alright for like an hour but then it seems like it leaned out, the idle speed came up a lot, and it tried to die if i was too quick with the throttle. But anyways, a pic of her out and about... | |
Age : 49 Join date : 2016-09-06 Points : 15654 Posts : 10975 Location : Oklahoma
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 11th 2018, 9:21 pm | |
| On your snorkle... this is how it still looked? Did you happen to drill out the hole for the bowl vent into the center chamber of your adapter? You might be getting some kind of vacuum issue. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 11th 2018, 9:30 pm | |
| I milled out a spot there on the adapter and filed a little slot in the lip on the carb. I know that wasnt the problem. I think I'll check the intake bolts/gaskets too | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 11th 2018, 11:45 pm | |
| That would probably solve it, if it ever even was the issue. I just dont know with this thing. Never had one fight me so bad before... | |
Age : 23 Join date : 2018-02-27 Points : 3841 Posts : 1299
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 17th 2018, 8:11 pm | |
| I've tried so much with this, it's hard to update... So I put a stock air box back on. It's still doing the same thing. Took the exhaust extension off. Still doing the same thing. I'm gonna try putting the other carb back on and then we'll see if it'll even run with that. I want to die a lot more than usual today Feel free to suggest more stuff that I've already done so I can try it a third or fourth time and confirm it doesn't help | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5091 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 18th 2018, 11:37 pm | |
| Maybe take the air cleaner back off and look down the barrel of the carb (from a safe distance and with goggles on) while it is running, to see the main jet and idle jet working. Maybe you would be able to see how the extra gas is getting in the engine. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 20th 2018, 11:09 pm | |
| You would be able to tell if something is not working right. Like for example, when the engine is idling and you see gas coming out of the main jet which would mean that the engine is idling faster then what was anticipated which might mean the idle jet is not working. It might give direction to what to look for, if anything. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 26th 2018, 11:08 pm | |
| Put the old carb back on. Runs good now. I even stole a good battery out of my parents mower so i can have electric start | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 27th 2018, 7:55 am | |
- Put the old carb back on. Runs good now. I even stole a good battery out of my parents mower so i can have electric start
Watch out, so your Parents wo'nt catch you! Put it back early enough before they will use it!! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 28th 2018, 1:25 am | |
| Oh they never use that mower. I'm the only one that has to mow the lawn so I use my beloved Snapper. And even if they did use it I'd put the battery in I took out of Mutt, it's still strong enough to start a single | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 28th 2018, 9:21 am | |
- Oh they never use that mower. I'm the only one that has to mow the lawn so I use my beloved Snapper.
And even if they did use it I'd put the battery in I took out of Mutt, it's still strong enough to start a single Nice! Sounds like a mower that never mows, only rots in the corner and will be scrapped soon | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I June 30th 2018, 10:59 pm | |
| Took her out of the store, pulled the right exec off, cleaned up the valve stem hole and put a new valve stem in, seems to hold air now. The front tires both have slow leaks but I'm not really concerned about those, they're pretty slow. Oh, and she still runs kinda crappy, even with the old carb back on. Not trying to stall, but definitely rough. Also the fully adjustable carb runs fine back on the oppy it came from, like pristine fine. Gonna go through the fuel line looking for a kink along with putting a new filter on and if that doesn't do it maybe I'll go for head gaskets and the coil. Feel like I'm getting closer to the issue though. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 6:28 am | |
| Try to smear some Engine sealing stuff between the old head gasket and the block and the head if they're reusable, to get cheap. Or buy a new Chinese oppy Carb for it, if they're cheap and good | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 9:43 am | |
| If the adjustable carb ran terrible, but good back on the engine came from and the original carb that ran ok is running not so great now. It may be an issue on the engine side would be my guess. Check for cracks in your intake and might check plugs and spark. Check those after you look at your fuel filter and cap. | |
| Subject: Re: Craftsman GT3000 "MUTT" July 1st 2018, 1:16 pm | |
| I suppose the fuel filter is plugged from the crappy gas that was put in her.
And Seb, we already established that it wasnt the carb, and no kind of sealant is getting anywhere near the head gaskets on this engine. I'm not that much of a hack. | |
Age : 24 Join date : 2016-04-12 Points : 5976 Posts : 2645 Location : Indiana
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 3:14 pm | |
| I very much doubt it. I've had this intake off and the gaskets were pristine. Also I sprayed carb clean around all connections and nothing changed. | |
