| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 3:14 pm | |
| I very much doubt it. I've had this intake off and the gaskets were pristine. Also I sprayed carb clean around all connections and nothing changed. | |
Age : 22 Join date : 2016-10-29 Points : 7226 Posts : 4022 Location : Lewisburg, KY
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 7:41 pm | |
| Put a full tank of gas in her and messed around for a bit. Even after blowing out the filter and getting the fuel line as straight as possible she still runs as crappy. Smells like she's running extremely rich too. Wonder if it's the coil missing? | |
Age : 24 Join date : 2016-04-12 Points : 5984 Posts : 2645 Location : Indiana
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 8:00 pm | |
| That’s possible. It must not be the carb if the carbs work fine on the other engines. You’ve narrowed it down to something on the engine. Coil seems very likely. Maybe just try a set of new plugs and see what happens? | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 8:04 pm | |
| Maybe I'll try another pair. Can't hardly read the plugs on oppys. If they're not black then they're not running right, and are probably overheating. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5336 Posts : 2561 Location : Rochester, New York
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 1st 2018, 8:49 pm | |
| How about one cylinder having way different compression that the other? Does the engine crank over really smoothly? or does it get faster, slower, faster, slower and so on? | |
Age : 49 Join date : 2016-09-06 Points : 15680 Posts : 10989 Location : Oklahoma
Age : 37 Join date : 2013-07-02 Points : 5022 Posts : 731 Location : Logan Ohio
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 4th 2018, 1:50 pm | |
| sounds like water in the gas, it will sit at the bottom of the fuel tank, will make your stuff run stupid. happened to me a bunch on various tractors. also had a couple carburators so old and worn, where the main butterfly operates the shaft was wore so much that air was sneaking in randomly and making me pull my hair out | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 4th 2018, 2:33 pm | |
| I have another gas tank to put in her, i might try that, then i can dump out and rinse this one. Kind of a waste of gas but oh well. Also this carb is nice and tight. Man, this gas tank is a pain to get out... Oh, and some pics of her out in the pond drain the other day. I found out i can make the 4ft drop into the one end if I'm careful | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4933 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 4th 2018, 5:32 pm | |
| On all my craftsmans before I ran them I disconnected the gas tank line and drained them then ran about 10 gallons of water though it to clean it out then let it dry in the sun for a couple of days toare sure everything was out of them | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3564 Posts : 825 Location : In the shop
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 5th 2018, 12:10 am | |
| Bet Noticed the fender had a bunch of cracks under the seat mount and some starting at the inside corners so i got on that instead. The old fender had already been given special treatment, so i decided to adapt it to this one. All welded in on this side. Top plate welded, she's solid now I didn't think to mask it, whatev lol. Oh and tomorrow I'll make something to lock down the rear rack. Oh and the gas tank is all on and hooked up but i didnt fill her or try to run it. | |
Age : 23 Join date : 2018-02-27 Points : 3849 Posts : 1299
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 5th 2018, 1:53 am | |
| yes how you do your welds to look good and hold the stuff together, so they wo'nt break if you hit the weld with a hammer or so | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 5th 2018, 2:04 am | |
| Well i took a semester mig welding class, but really MIG makes everybody look pro. Also helps to know where to have your settings for what you're welding. You can't hardly consider yourself a welder if you cant set up one.
If your welds break when you hit them with a hammer you either need to stop quenching them to cool them or you need to clean your base materials a lot better. It's a lot easier to weld clean metal than nasty rusty crap, and the beads look a lot jicer | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 5th 2018, 10:27 pm | |
| The large wires coming from the power lines feeding circuit breaker panels are usually Aluminum. Aluminum house wire is out there. It was used briefly during the 70s I think during a copper shortage. Due to the reactivity of Aluminum with other metals, it caused a lot of corrosion with led to bad electrical connections and fires. Still used commonly for service feeds though.
Back on topic. Great welds Rich. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 5th 2018, 10:33 pm | |
| I mean like muck said, mig is basically a big hot glue gun, it's not hard to pull off.
Put her all back together. Didn't feel like doing the rack lock. I ran her around for a bit but she still kinda runs rough. The stuttering is a bit better though. Still does the thing where if i run the front end up the rpms come up.
Oh and it's time for some new brake pads lol. I have no brakes and I'm outta room to adjust lol. | |
Age : 20 Join date : 2017-06-09 Points : 5495 Posts : 2640 Location : Literally Nowhere, Texas
