Craftsman GT3000 "MUTT" Part I
+27 Double W Cross Ranch
Dave.MTD
Cambren Scott wenger
sadeoo7
ConfederaSears
tater195
Jymmyee
Warren Evans
Rockinator
TheGreenHornet
Murryman
31 posters
Author Message The author of this message was banned from the forum - See the message SebastianAlbrecht Veteran Member
Join date : 2018-02-27Posts : 1299 muckmudd Established Member
Age : 22Join date : 2017-07-11Points : 3563Posts : 825Location : In the shop MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I July 10th 2018, 6:23 pm Nah if all else fails I'll put together the spare 18hp I have and then this one will run again. That's how it works, right?
Also this lol
VIDEO
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY The author of this message was banned from the forum - See the message SebastianAlbrecht Veteran Member
Age : 23Join date : 2018-02-27Points : 3848Posts : 1299 MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma Subject: Re: Craftsman GT3000 "MUTT" Part I July 15th 2018, 9:24 am That really sux. You have compression, good fuel delivery, new spark... almost has to be internal then? Or jealousy of "Budgie".
biggasmowers Veteran Member
Age : 24Join date : 2016-12-30Points : 4932Posts : 1944Location : Kansas Subject: Re: Craftsman GT3000 "MUTT" Part I July 15th 2018, 9:43 am Never had an issue with oppys and compression. Have had ones that had bad rings so they ran a little hot but other than that it was never enough to make them run badly except for burning just enough oil to create an invisible cloud of fumes that hung over you while driving
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I July 15th 2018, 11:46 am This is still all really strang to me because it's not running lean, it's running really rich. I don't even think the idle jet is being used, it's just using the main all the time. Just a theory though. Might start swapping around carbs again.
Age : 24Join date : 2016-12-30Points : 4932Posts : 1944Location : Kansas RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I July 15th 2018, 9:04 pm Prolly idk. Tried the one carb i didnt wanna try because it's a pain in the arse to take off(horizontal). I think she runs perfect, not gonna say for sure cause then it wont. Weoo. The carb that runs like crap still runs like crap on the good (and governed) engine. I mean it runs without surging, but it's really rough and it's obviously running fat. I'm putting together another carb together to put on this horizontal, luckily i found another main jet to put in one
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I July 16th 2018, 1:59 am Stole a headlight from Budgie's hood. Might take the LED back off now, really dont need it
Remnants of the old brake pads lol. I found another pad to replace the one side and i reused the other because i don't feel like getting cancer from cutting brake pads out today
Crazy_Carl Veteran Member
Age : 35Join date : 2017-10-30Points : 5335Posts : 2561Location : Rochester, New York Subject: Re: Craftsman GT3000 "MUTT" Part I July 16th 2018, 9:51 pm Don't let the safety people get in your head bud. Does look like the two headlights in the hood are plenty bright enough.
Age : 37Join date : 2013-07-02Points : 5021Posts : 731Location : Logan Ohio RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" July 17th 2018, 11:29 pm Yeah i might take that LED off, looks stupid. And thanks CC
Moved Budgie with er the other day
Age : 20Join date : 2017-06-09Points : 5494Posts : 2640Location : Literally Nowhere, Texas RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I July 31st 2018, 2:15 am What the heck was I on when i made this belt system. I literally have to take the drag link, clutch linkage, and a belt keeper off to get the belt off. Oh and she's getting a new belt tomorrow. This one has done well over the past year and a half ish, i think it's time to retire it
Age : 35Join date : 2017-10-30Points : 5335Posts : 2561Location : Rochester, New York RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Crazy_Carl Veteran Member
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I August 9th 2018, 9:15 pm I put the belt on a few days ago. I forgot the clutch has absolutely minimal travel with a really fresh belt, so it was kinda interesting in the lower gears where i couldn't rev match. She will slip if you have her in a high gear and push in the clutch. I have a plan to fix it(angle grinder maybe lol), if it doesn't wear in soon enough.
RockeyDA Established Member
Age : 30Join date : 2017-10-15Points : 3262Posts : 639Location : Bellefonte PA RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Craftsman GT3000 "MUTT" Part I August 18th 2018, 4:48 pm How in the hell is this thing the most active topic on the forum. It's not even a cool build.
Anyways i cut out a spot in the clutch mount and now there's a lot more travel.
