 Briggs and Stratton 12hp - Oil dipper?
2 posters
Briggs and Stratton 12hp - Oil dipper? Empty
PostSubject: Briggs and Stratton 12hp - Oil dipper?   Briggs and Stratton 12hp - Oil dipper? Icon_minitimeFebruary 19th 2016, 9:14 pm
Hi, I'm wondering if there is an oil dipper in a 12hp I/C engine. My aftermarket Conrod came with one but it doesn't fit. There didn't appear to be one on the engine originally either.
PostSubject: Re: Briggs and Stratton 12hp - Oil dipper?   Briggs and Stratton 12hp - Oil dipper? Icon_minitimeFebruary 20th 2016, 3:56 pm
On a vertical shaft engine I wouldn't think so. Doesn't it have the plastic gears with paddles driven off the cam gear? If the rod is the same otherwise you could cut the dipper off (I assume you mean it's cast as part of the rod). Otherwise send it back if possible and get a different one. Maybe some numbers got crossed or something.
PostSubject: Re: Briggs and Stratton 12hp - Oil dipper?   Briggs and Stratton 12hp - Oil dipper? Icon_minitimeFebruary 20th 2016, 4:35 pm
I've got the rod in the engine, the dipper isn't part of the rod. I think the rod fits in a couple different engines. And yes it does have the wee plastic paddles so maybe they splash the oil. Was just curious
» more rpms from a briggs 12hp flathead
» Briggs and Stratton 12hp Powerbuilt Idling/Reving too high
» 12hp briggs and stratton flat head torque specs
» Briggs 12hp air filter
» Briggs 12hp flatty oil
