 mst-206 How strong ???
2 posters
steeldaytonas
steeldaytonas
mst-206 How strong ??? Empty
PostSubject: mst-206 How strong ???   mst-206 How strong ??? Icon_minitimeDecember 12th 2015, 11:26 pm
as the title says
How strong is that transaxle??? HI run it with 30'' jeep tire no lock no pulley swap for now with 14hp briggs. I whis to know of it can handle it in trail because I didnt have a chance to try yet. Second how far it could support upgrade ???? like pulley swap , diff lock , more hp + Im looking to use 33'' tire because I have 2 I dont use and I thing it will look even better with it
PostSubject: Re: mst-206 How strong ???   mst-206 How strong ??? Icon_minitimeDecember 13th 2015, 11:12 am
Well I ran 24" tires on mine, but after about 6 months the case snapped under the differential. I had it geared to go 15 and I had a stock 18 hp opposed twin briggs. my brother was driving it and he hit a rut and it snapped. I would look for a stronger transaxle, or put a solid 3/4 shaft all the way threw it to make the axle. if it was solid mine wouldn't have broken.
steeldaytonas
steeldaytonas
PostSubject: Re: mst-206 How strong ???   mst-206 How strong ??? Icon_minitimeDecember 13th 2015, 12:16 pm
do you mean a solid axle or maybe a fully welded diff, it will become stronger what about the other gears in that case
PostSubject: Re: mst-206 How strong ???   mst-206 How strong ??? Icon_minitimeDecember 13th 2015, 5:58 pm
if you weld the diff gears together it would work.
» how strong is it
» What do you think is the most popular Tractor?
» F-N-R Transaxles = How Strong Are They?
» Strong lawn tractor?
» What is a good strong tranaxle that will go in a craftsman?
