| '86 Westwood T1200 | |
+18Crazy_Carl Mow Money Mods prancstaman TheBeal RichieRichOverdrive MightyRaze AllisKidD21 Doug STUNTMAN JON CraftsmanQuad19 Rockinator 1997 Murray RevDogg mr.modified KyleDeere79 bradtractor chevy8988 MatthewD 22 posters |
| Subject: Re: '86 Westwood T1200 April 27th 2017, 11:32 pm | |
| - mightyraze wrote:
- Got any videos of it running with that straight pipe. I bet it sounds sweet!
Yeah! Getchu a youtube channel and put up some vids! That'd be dope! exhaustooks good, bet it has a good thud to it! Don't roll it hahaha trust me it ruins most anything sticking up like that. | |
Age : 25 Join date : 2016-07-10 Points : 8591 Posts : 5190 Location : Ontario Canada
| Subject: Re: '86 Westwood T1200 April 28th 2017, 10:39 am | |
| Well you would know Rich! Hahaha just kidding, exhaust looks good! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5757 Posts : 1993 Location : Northern Ireland
| Subject: Re: '86 Westwood T1200 April 29th 2017, 7:00 pm | |
| The engine's currently not running due to an oil leak and fuel starvation. I am a bit concerned about the exhaust being rolled over onto, but hopefully I won't. I might also add a brace to reduce the chance of breaking the block if I land it on the left side.
Btw been looking at buying a 7/16-20 bolt. There appears to be 7/16-20 UNF or UNC ect. Does it matter what one it is? | |
Age : 49 Join date : 2016-09-06 Points : 15682 Posts : 10990 Location : Oklahoma
| Subject: Re: '86 Westwood T1200 April 29th 2017, 10:15 pm | |
| UN"F" just means "UNified Fine" thread. 7/16-20 is a fine thread bolt. The one you need.
UN"C" would be "UNified Coarse", probably a 14 or 16 thread.
| Subject: Re: '86 Westwood T1200 April 30th 2017, 5:38 am | |
| Thanks. Looking online, i can get 7/16 UNF Bolts that don't say 7/16-20. Would they work seeing as they are UNF. Sorry for the stupid questions | |
| Subject: Re: '86 Westwood T1200 May 13th 2017, 6:50 pm | |
| Haven't ordered up a bolt yet.
Decided to see if the engine would run today but it appears to be ceased. Don't know how that happened. I have to take the engine off anyway to fix an oil leak at the sump gasket so I'll take the head off and see what's up.
I never seem to have this thing going for too long before something breaks so I'm rebuilding the whole thing to make it better. | |
| Subject: Re: '86 Westwood T1200 May 14th 2017, 11:43 am | |
| Dunno. Pulled the engine off today and got the piston unstuck. Doesn't seem to be any marks on the cylinder liner. Next job is to fix the oil leak from the sump. | |
| Subject: Re: '86 Westwood T1200 May 14th 2017, 11:49 pm | |
| That's good news. Fix your oil leak and maybe it will be good to go again! | |
| Subject: Re: '86 Westwood T1200 May 17th 2017, 6:03 pm | |
| Took the sump off and cleaned the old gasket off and put some instant gasket maker on the surface. Been sitting for a few days now and there doesn't appear to be any oil leaks. | |
| Subject: Re: '86 Westwood T1200 May 17th 2017, 10:50 pm | |
| Sounds promising! Hope that thing fires right up for you! | |
| Subject: Re: '86 Westwood T1200 May 30th 2017, 12:42 pm | |
| Fired the engine up yesterday. At idle there is a bit of blue smoke which seems to be caused by a build up of oil in the combustion chamber because it disappears once you rev it. It's still leaking oil though, not too sure where it's coming from. | |
| Subject: Re: '86 Westwood T1200 May 30th 2017, 2:15 pm | |
| Man, I hope you do not have a crack in there somewhere. | |
| Subject: Re: '86 Westwood T1200 May 30th 2017, 2:38 pm | |
| I have a spare block and sump from the original engine if I need it. The leak seems to be coming from the exhaust side of the engine, but it could just be that the tyre is flat on that side. | |
| Subject: Re: '86 Westwood T1200 May 30th 2017, 4:11 pm | |
| You mentioned some oil is slipping by into the combustion chamber. Is it possible that some of that oil is slipping by the valve and out the exhaust port between the head and exhaust flange? | |
| Subject: Re: '86 Westwood T1200 July 8th 2017, 1:35 pm | |
| I don't think so. The leak seems to have stopped now. I do have some work to do on her to get her up and running. The rear pulley needs welded and the clutch needs finished. | |
| Subject: Re: '86 Westwood T1200 August 8th 2017, 10:05 pm | |
| Time for a build revival (I hope!) The oilleak appears to have stopped. I installed a slightly smaller carb onto the engine to give her more low end power. I'm also going to change the stack to a side pipe. | |
| Subject: Re: '86 Westwood T1200 August 11th 2017, 8:57 pm | |
| Thanks Mighty!
For the exhaust I think I might just quickly fab up a simple side exit exhaust, think it'll look good
I need to get the clutch working, get a front and rear pulley and a belt and it should be driving. The plan is to get it moving under its own steam and then improve on it. | |
| Subject: Re: '86 Westwood T1200 August 11th 2017, 9:07 pm | |
| Nice! What all are you thinking about improving on it once you get it driving? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: '86 Westwood T1200 August 11th 2017, 9:10 pm | |
| Building up the peerless 832 trans that I have, possibly locking it, figuring out throttle/choke, doing the brakes, heavy duty tow bar, bumpers, even maybe a forklift for the rear, who knows. | |
| Subject: Re: '86 Westwood T1200 August 12th 2017, 9:32 pm | |
| Exhaust looks pretty cool like that! Hahaha. Would probably be way too loud with that short little pipe though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: '86 Westwood T1200 August 12th 2017, 10:04 pm | |
| Thanks, I think it looks nice too. In the garage it's pretty loud but not much more than the stack was. Sounds real nice at low idle | |
