Welcome to my new build thread! This is my free and new to me MTD! I believe it to be identical @Brianator The Warhorse! I have done some basic tinkering with it. This thing def needs some work to get it to the point I want it at which is basically a lil romper that can do about 12ish MPH and still have a functional mowing deck. With literally no work besides stealing some keys from a diff tractor and some brake clean she lit right off.
The smoke is from some oil I put in the cylinder and as I let it run it cleared up and didn't smoke at all! I put a new chunk of fuel line on, put some gas in the tank and took it for a drive!
... and immediately got it stuck. lol No steering and flat tires don't go well with gravel. For not touching that carb it runs pretty well. Could be better but it is not super high on the list. What is high on the list is steering. I have some steering of a new MTD that I am going to swap on I just have to make a custom steering rod. So that will be one of the first things. Then a rear pulley swap is in order. I got the parts. I also got an ATV rack for the rear which is where I will mount the battery as you saw in the vid the positive and negative battery leads are ran on the floorboard. So, something custom there. Bust since the wiring all works, I am just going to relocate the battery to back there. For now, I got some tires that will go on it that hold air but, if possible, some ATV rear tires would be preferred. Besides that, just a service and we should be ready to go romping!
MightyRaze and JB_4x4 like this post
Age : 22 Join date : 2016-10-29 Points : 7223 Posts : 4021 Location : Lewisburg, KY
