| KohlerCoalRoller's Coast to Coast Trail Blazer | |
+3MatthewD Doc Sprocket KohlerCoalRoller 7 posters |
KohlerCoalRoller New Member
Age : 24 Join date : 2014-01-02 Points : 3987 Posts : 8 Location : Utah
| Subject: KohlerCoalRoller's Coast to Coast Trail Blazer February 1st 2015, 5:29 pm | |
| My basic idea of this tractor is to go anywhere and do anything that a normal 4 wheeler can do, but somewhat small and nimble to where I can go where they can't. Its a mid 80's coast to coast with a 11hp briggs and a 5 speed peerless 800 series. I am going to replace the 11hp with a 17 hp briggs opposed twin with a snorkel/cold air intake, side pipes or stack. It will have a slight lift(1-3 inches) ti will have big 24'' tall tires with a homemade hub on the rear. I am going to rebuild the clutch, rewire it, add lights and a winch, tool box and a pull start. It will be pulley swapped with a 6-4 and attempt to get to atleast 30mph. the transmission with be locked. Since it's a mtd product, I will have to make the flame a bit stiffer and add skid plates along with transaxle braces. These are the basic ideas that I want to make happen on this tractor. More stuff will be added when more money arrives this spring and summer. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7319 Posts : 2914 Location : Ontario Canada
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer February 8th 2015, 12:08 pm | |
| Well today I got the engine and transaxle out, now I need to make my own hubs and tear into the transaxle to clean and lock it. I also have to drill the old bolts out of the opposed twin to mount it. | |
MatthewD Veteran Member
802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3759 Posts : 146 Location : Vermont
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer February 8th 2015, 8:36 pm | |
| Cool build. Never heard of a "coast to coast" before but mtd has a bunch of brands. Are you sure your trans will stand up to 24" tires? I have a 801 series and it looks tough, but I don't know about 24 inch tires tough. | |
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer February 9th 2015, 10:03 pm | |
| He's working so fast on it that he didn't have time to get pics. I'll bet he'll get some soon when he pauses for a short break! Those craftsmans are kind of neat looking with those big square hoods. Good luck with it. | |
802 Customs Member
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer February 15th 2015, 8:36 pm | |
| Well things didn't go as planed, got the engine and trans out, but it being a mtd, it has the stupid flat axle shafts the rims are rusted on, didn't get the trans taken apart either and the opposed still sits in the shed. Then I got sick so its been a while since I went out to work on it, those tires are 23-8-11 so I think they would work for now unless I find something else. I also have to get a new plug for the oil drain for the opposed too. if the 801 breaks then I have a 930 5 speed and a new old spicer 4360 to use. | |
Age : 25 Join date : 2013-04-05 Points : 4963 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer February 15th 2015, 10:39 pm | |
| - 802 Customs wrote:
- Are you sure your trans will stand up to 24" tires? I have a 801 series and it looks tough, but I don't know about 24 inch tires tough.
My Ford YT came with a 801 and 23s so I believe it would be able to easily handle 24s. | |
| Subject: Re: KohlerCoalRoller's Coast to Coast Trail Blazer March 8th 2015, 6:54 pm | |
| Well nothing has happened lately, ive just haven't had the time or energy to get anything done. But ill try to get to the hardware store and get a plug for the opposed twin and try to get it started. | |
MurrayMayhem Member
Age : 25 Join date : 2013-01-03 Points : 4459 Posts : 99 Location : 820 Opposed Twin RD. AxleBreaker City
