| Kohler CH20S Not performing like it should. | |
hukturn New Member
| Subject: Kohler CH20S Not performing like it should. March 22nd 2011, 8:04 pm | |
| Kohler CH20S w/1bbl carb (in a Kubota GR2000) will not idle. Governor will adjust (choke out) periodically (about every 10 seconds or 15 seconds w/choke on). When this happens, engine chokes down to near stop but recovers, unless under load (blades engaged, hard turns). Some light black smoke when first starting and/or when I throttle up quickly. Engine/carburetor seems to have the most difficulty when at operating temperature and/or when under load. Runs/idles fine when cool (at startup) but has problems after about 5min of running. Runs/idles fine for longer period of time when at low idle. Seems to also have difficulty maintaining RPM when travelling up/down hills. I am not operating at high altitudes. Will run for longer at ½ throttle, but still shuts down over time and/r under load (ie; mower blade). I would not describe the overall idle as “rough” but it is also not “smooth”. Automatic choke was not opening fully (possibly 20degree butterfly), so I added a spring to allow full (90degree butterfly) opening when choke lever is disengaged. Thoughts?
Some things already done; Changed plugs Checked spark and has nice blue fire Adjusted the float levels (no cracks/holes) Adjusted external governor spring (there is tension on governor rod, so it is engaging) Good fuel flow up to carburetor (and bowls have fuel) Slow speed jet O-Rings are good Oil level is good Removed fuel filter and air filter for testing during repair (still problems) New gas w/carb cleaner additive Ran w/out gas cap
| Subject: Re: Kohler CH20S Not performing like it should. March 22nd 2011, 9:08 pm | |
| Magneto could be on its way out - when its cold itll be fine- but once it warms up and heat makes it expand- then thats where the issue lies. Sort of like points on old tractors- fine when theyre cold, but once they heat up theres issues.
Have you made sure the flywheel is clean? Has the magneto been properly gapped? I use a piece of cardbord from a oil filter box as my gap width- set it between the flywheel/magneto ( with it loose) and let it snap to the flywheel - then tighten it down.
Its also possible the magneto could be grounding out - try unhooking the magneto ground wire and see if that helps in its running - could indicate a problem with the ign switch as well.
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
