Sure is @Threewheela but I'm hoping to prove you can ditch it and the coil for a standard coil, I have a CV16S and a standard coil for it but I need to elongated the slots before I can actually test it out.
I recently swapped a coil from a courage onto a CV16 to delete the advance box and it runs fine. The one I used was already slotted plenty. I hope to post the whole build on here soon. Going to be a 4x6.
Hillbilly mowers likes this post
Hillbilly mowers Member
Age : 37 Join date : 2023-10-12 Points : 725 Posts : 291 Location : Booneville ky
Here is 2 gaskets kit that the numbers bring ups for this engine from eBay but which one would be the best an last longer cause there is my price range but Im think on the 20 dollar one cause it's high quality.
Age : 49 Join date : 2016-09-06 Points : 15597 Posts : 10945 Location : Oklahoma
@threewheela is there another way to rewire the whole with out that box and it run with a push button start and a kill switch for both coil if I bought 2 of the signal prong coils for this engine.
I don't see why that wouldn't work. All you would need is a wire to trigger the starter relay and one to ground the coils. Just do some double checking on the shape/style of the coils before ordering to make sure they should fit. The aftermarket ones seem to come in a few different shapes from what I've seen.
Brianator Moderator
Age : 45 Join date : 2019-07-02 Points : 4525 Posts : 2385 Location : Ontario, Canada
@Threewheela that's awesome! Do you remember what model Courage? That would save me the hassle of elongated the slots in the one I have.
This is the coil used on the CV16 to delete the box.
Hipa 20 584 01-S
I originally used one from a junk Courage engine and it worked fine so I ordered a new one. Can't remember the exact model engine but I think it was 19hp. Again, maybe I'm wrong about your application but just do some double checking before you order. heck, one coil is only $15. You could just order a second if it works like you want.
Brianator Moderator
Thanks for the tip @Threewheela, I've looked and it looks similar to the one I got (which sits about a 1/4" back from the flywheel) BUT has more meat around the slots to work with and who knows, maybe it's actually spaced closer from the get go!?
