| Kohler 7000 series engine build | |
Mtdmudmower Member
Age : 42 Join date : 2019-02-03 Points : 2169 Posts : 39 Location : West Salem, Ohio
| Subject: Kohler 7000 series engine build February 9th 2020, 1:21 am | |
| I'm going detail some of the 7000 series Kohler engine build ideas I have here starting off with cylinder head modification. For one the ports are fairly open requiring only some minor port work for optimum flow. Pics will be posted once I get a clear shot on the original heads. I've already modified the second set.
Last edited by Mtdmudmower on February 9th 2020, 6:59 pm; edited 1 time in total | |
| Subject: Re: Kohler 7000 series engine build February 9th 2020, 8:12 am | |
| Cool! Looking forward to the pictures of this one. Is it a KT Series 1 or 2? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 9th 2020, 6:56 pm | |
| I think I need to change the title of my post just a bit. So this is not a kt17 which is apparently the kt series. Also happens to be an opposed. This build is the newer kt735 model number which I realized is called a 7000 series despite it having kt in the model number. My bad. | |
| Subject: Re: Kohler 7000 series engine build February 9th 2020, 7:00 pm | |
| Ah, so it's a V-twin then. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
prancstaman Veteran Member
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 9th 2020, 7:17 pm | |
| Yes it is a v-twin. Not even one of the bigger ones in that line of engines. Although it is fairly big at 725cc which is right about 44cubic inches. The way it's built leaves lots of room for really dragging the power out of it. | |
| Subject: Re: Kohler 7000 series engine build February 9th 2020, 9:59 pm | |
| Sounds like it has potential to be a real powerhouse! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 10th 2020, 7:07 pm | |
| I'm hoping so. I've got new valve springs new rocker arms with a better ratio coming that aren't here yet. I'll detail it all as I start posting up the pics. I'm waiting on the rocker arms. So I can start tearing into it and show everyone what I've learned and how I figured it all out. | |
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 13th 2020, 8:04 pm | |
| Would be easier to cut the springs to size with a cut off wheel and a jig to hold it. Be easier then redoing the valvetrain geometry or cutting the head up. Springs are definately stronger then stock. | |
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 13th 2020, 10:29 pm | |
| Cutting is not the best option here cause you loose the flat end and increase your spring rate. These will have 40lbs of seat pressure. Which is a lot more than the stock spring. I disassembled the stock ones rather easily by hand. As far as increasing the valve height is a simple fix to keep the geometry the same by just adjusting the pushrod the same length. It just moved all upward meaning if need to make a space for the valve cover. Which I will likely need to do any way with the new rockers. | |
Mtdmudmower Member
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build February 29th 2020, 8:49 pm | |
| Here's a trick to removing the engine flywheel I learned a few years ago. First you need to remove the bolt or nut depending on the engine. Second thing is you will need a pry bar and a hammer. So on the ones with a bolt you'll run the bolt back in against the crank minus any washer. This will protect the threads from any damage as well as the crank end. On ones with a nut you'll want to install the nut till the threads are flush with the top of the nut. I recommend using a dead blow or other heavy but soft faced mallet on this style. The next step is easy find a suitable position to pry upward that won't damage anything and then start giving swift blows to the nut or bolt. Believe it or not after a few good strikes the flywheel will pop free from the tapered seat on the crank. No puller needed and works good in a pinch. | |
Mtdmudmower Member
| Subject: Re: Kohler 7000 series engine build April 12th 2020, 2:21 am | |
| Well I'll call it phase 1 at this point. Due to the pandemic parts and progress on my build have been on hold. However I've installed the carb on my other motor that's stock. It's very lively. Carb is a Chinese pwk keihn knock off 34mm carb that's $28 of of Amazon. Ran rather fat at first after adjusting the needle and the isle air mix it seems very happy. Slide does not always return to the same resting point off throttle so adjusting the cable is a bit tricky. Otherwise I'd say I'm happy with it. | |
Mtdmudmower Member
