 Peerless 801 or MST 205?
Peerless 801 or MST 205? Empty
PostSubject: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 8:29 am
I'm sure most of you know that I've entered the 2015 build off and I'm making a mud/utility tractor.
I originally was going to use a Peerless MST205 but now I think I could get my hands on a Peerless 801 so I wondering what one is more heavy duty/better?
GenevaCustoms
GenevaCustoms
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 10:20 am
I'm pretty sure fearlessfront uses a 205 and he said he's used it for years but I think he only runs 20x8 inch tires. I don't know about the 801 could be stronger but I don't know by how much becuase the 820 is the only one I know of with 1inch axles besides like the horizontal input transmission
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 2:09 pm
I would sooner use the MST transaxle.
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 2:18 pm
Thanks. Should I go for the MST 205 then?
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 6:31 pm
I honestly think the 800 series is a bit physically stronger. I like the cast iron diff carrier, and the dimensions of the gears. However, the MST has benefits, too. Gear-drive reverse, and factory oil-lube.
Your call.
GenevaCustoms
GenevaCustoms
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 6:42 pm
Your call.
what do you mean a diff carrier? Is that like the 820s? We're the differential gears are enclosed? If that's the case I would probably go with the 800 series also lol
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 14th 2015, 6:50 pm
On an MST or 900 series (and many others) the bull (ring) gear and differential assembly just kinda floats in the bearing bores of the case. About as cheap as they possibly could have managed.
In the 800 (and 600 and others) the differential assembly includes a cast iron carrier to hold it all together, and it rides on bronze bushings. Much beefier.
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 15th 2015, 6:06 am
Could I swap the 801 diff carrier into the 205?
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 15th 2015, 9:43 am
Nope. Completely different architecture. Pick one.
PostSubject: Re: Peerless 801 or MST 205?   Peerless 801 or MST 205? Icon_minitimeFebruary 15th 2015, 10:10 am
Okay, I`ll just go for the MST then.
» Peerless 820's
» Peerless 777 use ?
» Peerless 822
» peerless 820
» New peerless 206 for 25$
