ok so im going to put on a brake pedal, i started working on it today. parts needed:
grip (From murray deck engagement lever)
deck level hard ware 1999 and newer. (i Think)
curl spring.
cut grip about here, then put on short end.
this is how the pedal will be set up....
then take small peace of grip, and cut of rest of the ribs...
then the now spacer will fit in the spring like so....
now bend the hook end of spring like this....
then i drilled a 11/64 hole for the other end of the spring to fit in. measure/position this from the hole with the notches in it. not the hole you see here....
then the spacer goes here
then it goes together like this
now to keep it from springing back past the spring, put a hose clamp on it and give it some paint
it will then be mounted like this
and then i will have a cable going straight to the brake lever.
i should change my username to picture man
