 Smoking carb
5 posters
lawn chief life
lawn chief life
Smoking carb Empty
PostSubject: Smoking carb   Smoking carb Icon_minitimeDecember 9th 2014, 12:07 pm
So I recently got my speed mower running. The new muffler Is close the carb and after shutting it off I noticed there was smoke coming out of the carb after shutting it off. Do t know what's going on here or if I should be worked.
Thanks lawn chief life
Smoking carb Empty
PostSubject: Re: Smoking carb   Smoking carb Icon_minitimeDecember 9th 2014, 12:30 pm
Was it smoke, or was it vapour? Sometimes one can be confused for the other.
That said, I think you may want to consider either relocating the exhaust, or constructing some sort of heat shield. In addition to some potential for fire, there's the potential for vapour lock, and even a reduction in power due to the heat.
Smoking carb Empty
both of my old, worn out engines do that. We have a kohler command V twin that does it, and the tecumseh on my bolens does it. i wouldnt worry about it
Smoking carb Empty
PostSubject: Re: Smoking carb   Smoking carb Icon_minitimeDecember 9th 2014, 1:03 pm
I am not so sure. my monky wards did that, and it was fuel leaking into the engine. it caught on fire and burned my hand.
willysjeepmb
willysjeepmb
Smoking carb Empty
PostSubject: Re: Smoking carb   Smoking carb Icon_minitimeDecember 11th 2014, 12:11 am
I have heard of vapor lock. What exactly is a symptom of it or what does it do?
Smoking carb Empty
PostSubject: Re: Smoking carb   Smoking carb Icon_minitimeDecember 11th 2014, 7:49 am
Basically, vapor lock is the result of fuel boiling (changing from a liquid to a gasous state) within the fuel system, be it lines, pump, or carb. Symptom? Fuel starvation, despite everything working properly.
Smoking carb Empty
Smoking carb
» Tecumseh hh100 carb
» help need cub 106 carb
» WHYS MY KOHLER SMOKING?
» Wiring problem... Stator smoking
» Briggs and Stratton twin smoking when running
