| Wiring problem... Stator smoking | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2853 Posts : 582 Location : Reeses Mill, WV
| Subject: Re: Wiring problem... Stator smoking September 24th 2020, 1:25 pm | |
| It could be a bad solenoid grounding out inside. That being the weakest link currently. I would disconnect your battery as well if that is getting hot. Possible the stator is fried and grounding itself out. | |
| Subject: Re: Wiring problem... Stator smoking September 24th 2020, 2:01 pm | |
| Sounds like stator diode is bad and battery is shorting back through with high current. Check that electricity isn't backflowing through the diode. There should be no voltage through the charging wire with the engine off.
If you have an ammeter(amp meter) in the charging circuit you will see a massive discharge. | |
| Subject: Re: Wiring problem... Stator smoking September 24th 2020, 3:11 pm | |
| Forgot to get back on here after I figured out what happened. Push Button Start wasn't worked because it went bad. Other problem was when I jumped the bad Solenoid to fire engine wires had touched each other causing it to short out and sent high current to the stator. Don't know if its fried or not. All I wanted to do was make sure everything worked before I taped it up. I'll never do that again. | |
| Subject: Re: Wiring problem... Stator smoking September 24th 2020, 3:42 pm | |
| If your stator still charges it's fine. I've accidentally given them a good cooking. They tolerate more than you'd think. | |
| Subject: Re: Wiring problem... Stator smoking September 24th 2020, 8:32 pm | |
- If your stator still charges it's fine. I've accidentally given them a good cooking. They tolerate more than you'd think.
Thats good to here. We shall see. Time will tell. | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4059 Posts : 870 Location : Phillydelphia
| Subject: Re: Wiring problem... Stator smoking September 26th 2020, 10:09 pm | |
| - MightyRaze wrote:
- So do you think those spades were touching like mentioned on FaceBook.
yep. George Irwin caught a glimpse of it in a photo. | |
