 Briggs stator problem
offroadredneck
offroadredneck
Briggs stator problem Empty
PostSubject: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 2nd 2013, 9:59 pm
I have a 12HP flathead Briggs and fininshed wiring it today using fearlessfronts wiring diagram and the stator charged the battery great but when it turned it off I noticed the stator was drawing about 3 amp. any ideas
CornishMorgan
PostSubject: Re: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 3rd 2013, 7:42 am
Stupid question but have you connected the ammeter the right way round? If you have the wires wrong on the ammeter it will say -3 amp when in fact its +3 amp. I would connect up a small 12 volt motor or lamp, connect 1 wire to the charging circuit and on to the ground. If you motor or lamp comes on when the engines running, your alternator is working fine and you have the wires on the ammeter the wrong way round. If the motor or lamp doesn't turn on with the engine, You have an alternator problem.
Was the charging circuit working normally before you worked on it?
offroadredneck
offroadredneck
PostSubject: Re: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 3rd 2013, 9:56 am
I tested the lamp thing and it worked but when I went to charge the battery it uses 3 apms when the battery is connected to the mower. another thing is I hear a small tic sound coming from under the flywheele. Ill take the flywheele off today and clean the stator.
CornishMorgan
PostSubject: Re: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 3rd 2013, 2:28 pm
Well is the alternator is able to power the light, without the lamp or the alternator being connected to the battery then you it should simply be that you have the wires on your ammeter the wrong way round.
PostSubject: Re: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 3rd 2013, 3:56 pm
It shouldnt be drawing anything when its off, you probably have your wires on your ammeter wrong. The alternator doesnt take any load because its not motorized.
offroadredneck
offroadredneck
PostSubject: Re: Briggs stator problem   Briggs stator problem Icon_minitimeFebruary 14th 2013, 11:50 pm
Yesterday I took off the fly wheele and found only half of my stattor. Question
The other half was gone and I could tell it had melted
» Flywheel/Magnet /Stator problem Briggs 14.5 hp
» Briggs Opposed Twin Governor Problem
» briggs and stratton v-twin need exaust idea and stator problems
»  Briggs and Stratton problem
» briggs carb problem
