| Smoking Belt?! | |
rockinromac1 New Member
Age : 19 Join date : 2017-09-24 Points : 2630 Posts : 9 Location : Southwest Harbor, ME
| Subject: Smoking Belt?! July 29th 2018, 4:16 pm | |
| Hi all, I swapped my pulley on my tractor last night and put the belt on it this morning. I went from a 8 inch pulley to a 5 inch pulley and from a 90 inch belt to an 83 inch belt. I took it out for a test drive and I had to push down the clutch/brake petal to get it to move. Then the belt started to smoke. What might cause this? | |
| Subject: Re: Smoking Belt?! July 29th 2018, 4:53 pm | |
| You may have the belt routed wrong or the brake stuck on and making the belt or the brake (or both) smoke | |
| Subject: Re: Smoking Belt?! July 29th 2018, 8:28 pm | |
| I did have the belt routed wrong fixed that. It now squeaks when driving, and when its in neutral you can't push it. The wheels are locked up and you have to push it along the ground. Is it normal for you to have to put it at high throttle to get it to go forward without stalling? | |
| | | AllisKidD21 Moderator
| Subject: Re: Smoking Belt?! July 29th 2018, 8:30 pm | |
| Yeah it definitely sounds like the brake is locking up somehow. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Smoking Belt?! July 29th 2018, 9:22 pm | |
| Your brake linkage may be out of adjustment, that would most likely be the culprit | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5492 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Smoking Belt?! July 29th 2018, 9:59 pm | |
| Yeah, sounds like the brakes. Try loosening that nut, should free up the brakes. | |
| Subject: Re: Smoking Belt?! July 29th 2018, 10:06 pm | |
| I wouldn't loosen the adjustment nut, because then the brakes won't work. It's clearly a linkage problem if everything was working fine before, so I'd say start with the linkages. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Smoking Belt?! July 30th 2018, 9:34 am | |
| Breaks seem to be fixed... When I push it then press the petal it will stop. I was looking under it when I adjusted the brakes and I was missing a cotter pin on the shifter.. Might be why it was popping out of gear! I also noticed that the belt was rubbing on the shifter so I rerouted the belt to the inside of the shifter instead of the outside. When I went to take it for a test drive because I have only been driving it for shout periods of time the battery is dead. It is on charger now and I will message back wether it works or not. How fast should I expect it to go? Anything I definitely need to keep an eye on? | |
| Subject: Re: Smoking Belt?! July 30th 2018, 9:36 am | |
| Well, when I did that to mine, it went about 9 MPH. And, yes, when you are done, feel the transaxle to see if it's warm or hot, if it is, the oil may need to be topped off. | |
| Subject: Re: Smoking Belt?! July 30th 2018, 12:44 pm | |
| I just took it out for a test drive and it goes 13.5 MPH compared to 7 MPH before! The transmission feels fine and I am still adjusting the breaks by the method listed by Double W Cross Ranch. Thanks for all your help in my journey! I will message back if anything else happens. | |
| Subject: Re: Smoking Belt?! July 30th 2018, 9:42 pm | |
| Nothing wrong adjusting it that way especially if the linkage adjustment rod is loose. Be cautious that making it too loose will remove your brakes. | |
| Subject: Re: Smoking Belt?! July 30th 2018, 9:46 pm | |
| Yep.. Learned that the hard way when it started rolling down the hill! | |
| | | | | Smoking Belt?! | |
| Who is online? | In total there are 96 users online :: 0 Registered, 0 Hidden and 96 Guests
