 how to put on hood without any brackets
dugan978
how to put on hood without any brackets Empty
PostSubject: how to put on hood without any brackets   how to put on hood without any brackets Icon_minitimeMarch 9th 2011, 6:14 pm
i have the hood to my craftsman but have no brackets or anything to mount it on the tractor how do i mount it?
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: how to put on hood without any brackets   how to put on hood without any brackets Icon_minitimeMarch 9th 2011, 8:42 pm
make brackets? out of somewhat thin gauge steel
PostSubject: Re: how to put on hood without any brackets   how to put on hood without any brackets Icon_minitimeMarch 10th 2011, 3:19 pm
Have any angle or spare tractor parts lying around ? Ive built a couple of my own brackets from old deck hangers .
Make sure the hood is where you want it first- then cut/fit brackets ( either weld to frame or bolt ) - most hoods the grille stays put while the hood opens- some open completely- for something like that you could use a solid round stock bar and some steel tubing ( that fits over it) - cut the open tubing into 3 or 4 pieces- 2 will weld to the hood, 2-3 will weld to the brackets ( line them up so theyre not in the same place) - then stick the solid bar thru to hold it on/let it swivel - drill a couple small holes for pins to hold the bar in place.
» First ATLT build, 18 hp vtwin issues with the transmissions mounting brackets
» How do I quiet down my hood and hold in place
» A "WOODY" Hood?
» my hood broke!!!!!!!!
» The Hood Scoop
