 kohler command 12.5 problems
jonjunk
6 posters
jonjunk
jonjunk
kohler command 12.5 problems Empty
PostSubject: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 9:42 pm
Hey guys the spark plug wire in my kohler command is shot, anybody know how to replace just the wire it is connected directly to the magneto, its a long shot but if its possible ill try it.
I have a kohler command 14 hp magneto that im going to put into the 12.5 but I would hate to decommission that motor over the magneto.
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 9:54 pm
as far as i know, you have to replace the coil. you can pick one up fairly cheap
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 9:57 pm
you might be able to do it. i've never pulled one apart before. I know a spark plug wire is universal.
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 10:01 pm
What does the wire look like? I've cut open a new car's plug wire and apperently its grafite something or other inside. Black, feels like a pillow feather, and nothing gets on your hands when you touch it. Never knew about it until i saw it, i was in shock expecting wires.
jonjunk
jonjunk
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 10:03 pm
this one isn't really removable from the looks of it, most plug wires have a snap connector on both the spark plug side and the coil/distributor side, this one looks permanently mated to the coil/magneto.
EDIT: the wire itself is a regular spark plug wire it is just permanently connected to the coil and I want to seperate the two so I can put a new wire on it.
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 10:21 pm
Can you get a photo of the coil? some of them have a seam down the middle of the plastic part you might be able to split?
jonjunk
jonjunk
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 10:24 pm
I can possibly get one tomorrow afternoon after work, but the mower is at my uncles, I am planning to pull the coil off the 14 hp tomorrow and if I get over to my grandmas place Ill take a pic.
jsisti845
jsisti845
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 24th 2014, 11:33 pm
im pretty sure you can just cut it and leave some slack and sodder some new sparkplug wire on and wrap it with some electrical tape or use some shrink wrap...... I could be wrong tho
mudpatrol1
PostSubject: Re: kohler command 12.5 problems   kohler command 12.5 problems Icon_minitimeAugust 25th 2014, 1:22 pm
if the coil wire is a metal core then you can repair/replace the wire. although i dont reccomend this for a long term repair,it can be done.check ebay for a coil replacement
» 15.5 HP Kohler Command Being Dumb.
» Kohler Command 13 ohv governor question
» Kohler command 20 "governor hunting"
» Get more horse power out of a kohler command
» need help quick! Kohler Command wont crank.
