 need help quick! Kohler Command wont crank.
need help quick! Kohler Command wont crank. Empty
PostSubject: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 4:31 pm
my motor was running fine, and then i shut it off, when i tried to start it again it wont crank, i changed the plug, it still wont crank, it isn't getting spark need help really quick, its a kohler command 16 hp
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 4:34 pm
check your kill circuit - the ground wire from the coil assembly. I bet its cutting the spark off.
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 4:47 pm
have that wired to a flip switch, think the swith might have shorted?
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 5:05 pm
By crank, do you mean it wont catch and run, or that it wont spin at all?
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 6:07 pm
Try bypass the switch.
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 6:58 pm
possibly yes. That or it is shorted near the terminal on the coil.
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 8:49 pm
got it running, i tested everywire and switch with a tester, the kill switch was shorted, replaced it, still didnt work, turns out the motor wasn't grounded all the way, fixed that and it crunk right up
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 11:42 pm
Awesome Smile
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 13th 2013, 11:48 pm
check out the build thread, i got a test drive vid up
PostSubject: Re: need help quick! Kohler Command wont crank.   need help quick! Kohler Command wont crank. Icon_minitimeApril 14th 2013, 12:01 am
sweet! I should have pics and vid up by mid-week of mine, running a bit behind schedule
» Cold Kohler Command 20.5 wont start..
» Get more horse power out of a kohler command
» kohler command 12.5 problems
» 15.5 HP Kohler Command Being Dumb.
» Kohler Command 13 ohv governor question
