| | Can't find tires for my rim... Help? | |
Carshowkid Member
![Carshowkid](https://2img.net/u/2812/37/66/46/avatars/1859-82.jpg)
Age : 25 Join date : 2014-07-22 Points : 4097 Posts : 347 Location : Downers Grove Illinois
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Can't find tires for my rim... Help? August 23rd 2014, 10:30 pm | |
| I have some rims that have some turf savers on them... I want to put some off road tires on the rims... But I can't find a tire that will fit... The size on the turf savers says 15x6-6... Please help! | |
| ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Carshowkid Member
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 10:53 pm | |
| How tall are trail wolfs? Cause I have fenders... And I like my fenders... And w/ fenders... I can only fit 18 inch tall... Barely... Depends though | |
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 10:58 pm | |
| - Carshowkid wrote:
- How tall are trail wolfs? Cause I have fenders... And I like my fenders... And w/ fenders... I can only fit 18 inch tall... Barely... Depends though
Edited my post for some tires i found. | |
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 11:03 pm | |
Edited my post for some tires i found. Thanks red... But can I fit a 7 wide tire on a 6 wide rim? And I also have front rims... They are ok for now... Just they are 11x4-2... I can't find any tires for those... Even can't find street tires | |
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 11:05 pm | |
| - Carshowkid wrote:
- redlinemotorsportts wrote:
Edited my post for some tires i found. Thanks red... But can I fit a 7 wide tire on a 6 wide rim? And I also have front rims... They are ok for now... Just they are 11x4-2... I can't find any tires for those... Even can't find street tires Yea you are totally fine. i think most rims come with tires one inch wider then the rim stock. Like my rear 12" rims are 7" wide and have 8" wide tires on it. Witch is perfectly fine. Heck, ive seen people put 12" wide tires on 8" wide rims no problem. | |
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 11:09 pm | |
| Ok... Cause I was even gonna try and find a set of tires that would my golf cart rims in the backyard... And just find hubs for those... But no one had any tires for those things either | |
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | Subject: Re: Can't find tires for my rim... Help? August 23rd 2014, 11:15 pm | |
| really, the only size you need to worry about is the bead size, which is the last number. try to get as close as possible to the rest of the numbers though. first is height of the tires, 2nd is width, 3rd is bead size
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![Can't find tires for my rim... Help? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Can't find tires for my rim... Help? | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
