Well I bought a 820 off facebook thinking I got a good deal for a working transaxle that the guy even said was race ready >.> Well... It was ready to race if I wanted to push it down the road myself.
So this is what it looked like when I got it all happy and thinking I was awesome!
Stretch is gonna recognize the shifter lol
Then I got to messing around with it checking gear ratios and stuff wondering if it already had the ratio conversion. I started noticing it was hard to shift sometimes it would just stop and wouldnt go in gear thought well thats odd. Then once I got it to shift all the way over to 6th the axle wouldnt turn when I turned the input pulley >.> Another huh thats odd moment, so I got out the sockets and started pulling it apart and much to my dismay and blood pressure 6th gear was completely gone I found chunks of gear in the case even blocking the fork... then I started looking at other things...
6th gear? GONE! Shift keys? Nice and rounded!
What used to be a gear
I took a look at the shaft and realized they didnt press out the needle bearings so its all galled up :/
And then today I poped the differential open to peek inside. It was packing a mighty fine piece of steel in it BUT it is completely useless because it was welded to split collars that let go of the weld so it would have just spun inside...
Ugh I hate people like this! Why do this to such a poor soul. ***** like that gets me going.... I just sold a mst 205 to a kid in Michigan, and I took pics from when I bought it, of the inside gears, outside case, ext. that stinks man hope you get her together soon!
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4877 Posts : 919 Location : Defiance, Ohio
yeah :/ coulda been honest about it still woulda bought it just woulda jewd em down a little >.>
Yea, looks like you got useful stuff like the axle, rotor, hubs.. I'm not sure about you but I'd give him a little piece of my mind about the condition.
rotor is welded to the axle the hubs are meh Ill have to either change my rims or adapt them so I may just get new rims well see as for the axle its all galled up so pretty useless atm ground a flat spot where the keyway was which screwed up the needle bearings :/
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4345 Posts : 491 Location : Index, Washington
