| Lower steering wheel? | |
noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5370 Posts : 252 Location : DFW Texas
| Subject: Lower steering wheel? January 16th 2011, 3:51 pm | |
| does anyone know a simple/cheap way to lower the steering wheel. and also so easy/cheap(if thats possible) way to do direct steering? i need like a list of parts cuz i can figure it out by looking at pics:( want it to come out bout where the red dot is Thanks | |
| Subject: Re: Lower steering wheel? January 16th 2011, 4:25 pm | |
| If youre moving the steering wheel- might as well go the extra mile and go direct steering - i dont think the stock steering gears would let it sit back that far- then youd need some sort of bushing/bering to hold the wheel in the new place- since its a steel dash, you should be able to bolt it right to the dash , but id put extra bolts or weld the dash onto the chassis. | |
| Subject: Re: Lower steering wheel? January 16th 2011, 5:51 pm | |
| could you explain exactly what i would need and how to do it to do direct steering? or send me a link of some good instructions? i Googled it but didn't find much but i didnt look for long | |
| Subject: Re: Lower steering wheel? January 17th 2011, 11:57 am | |
| Its similar to a tie rod or steering link - its a solid core rod with adjustable hiem joints on the end - so it can flex and make easy adjustments ( if it steers too far to the left and not the right- then it can be tweeked to steer more to the right). | |
| Subject: Re: Lower steering wheel? January 22nd 2011, 6:25 am | |
| I bot a couple tie rod assemblies from northern tools designed for go karts- im gonna try them, but i might upgrade to something bigger/stronger . Id say try your local farm and family center ( TSC) - they have all kinds of stuff . | |
| | | Yamaharules163 Member
Age : 30 Join date : 2010-02-12 Points : 5468 Posts : 60 Location : Winnipeg Manitoba
| Subject: Re: Lower steering wheel? March 8th 2011, 11:24 pm | |
| is this a off road machine or a "racing" mower. if its off road, this setup isnt worth it. You will have no steering torque if you get what I mean. | |
| Who is online? | In total there are 39 users online :: 0 Registered, 0 Hidden and 39 Guests
