| murray widebody steering wheel removal. | |
+4redlinemotorsportts willis923 LAWN MOWER MUDDER goesman 8 posters | Author | Message |
goesman Member
Age : 45 Join date : 2012-01-18 Points : 4850 Posts : 119 Location : Salem, Mo.
| | | | LAWN MOWER MUDDER Established Member
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 10:06 am | |
| I honestly have no clue, but I think there is two bolts that hold the column to the frame. Check where the steering shaft goes thru the frame. | |
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 11:22 am | |
| not too familiar with wodebody's however- most steering wheels are generic. theres a bolt in the center, covered by a piece of plastic. just pop the center piece out and take off the nut. the wheel SHOULD come off. if its rusted on, soak the piss out of it with PB blaster, and it THAT dont work, use Redneckcomputergeek's candle wax trick. look around the sides of the wheel if neither of those work, some wheels set screws too | |
| | | | truckin42 Veteran Member
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 12:30 pm | |
| I had the same problem with my JD l120 lawn mower.
What I did to take the steering wheel was took a sledge hammer and started beating the bottom of the steering wheel till it finally came off..And if that don't work try cutting it off or take a tourch and melt it off. | |
| | | goesman Member
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 8:12 pm | |
| it doesnt have a bolt or nut holding it on. Who knows what holds the goofy thing on. Oh well i think im going to go to handle bars.
Thanks, any way | |
| | | Doug Site Owner
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 8:20 pm | |
| Take pics of it.
Red, to remove the wheels off my MTDs I just found a bolt in the same thread but longer, threaded it in all the way, and while holding the wheel hit the bolt with a hammer. Freed up and came off. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: murray widebody steering wheel removal. March 15th 2014, 8:29 pm | |
| - Doug Fackler wrote:
- Take pics of it.
Red, to remove the wheels off my MTDs I just found a bolt in the same thread but longer, threaded it in all the way, and while holding the wheel hit the bolt with a hammer. Freed up and came off. Didnt think of that! .......duh | |
| | | Doug Site Owner
| | | | CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4233 Posts : 337 Location : Woodville Al
| Subject: Re: murray widebody steering wheel removal. April 9th 2014, 8:08 am | |
| Murray put a clip on atot of widebody. Look under the bottom of the wheel there should be a slot where there is a wire style C clip holding the wheel to the shaft pull it out and wheel should slide off | |
| | | mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4591 Posts : 327 Location : Rindge, NH
| | | | Sponsored content
| Who is online? | In total there are 25 users online :: 1 Registered, 0 Hidden and 24 Guests BallaSackMost users ever online was 412 on January 7th 2023, 7:59 am |
