| Stock muffler teardown | |
+9Ariens YT11 B440 RCG untrusty huskee mr.modified Thunderdivine craftsmancole willis923 Angchor 13 posters |
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4385 Posts : 491 Location : Index, Washington
| Subject: Stock muffler teardown April 24th 2014, 12:50 pm | |
| Has anyone ever carefully cut apart the stock factory muffler on something like the Kohler command?
I'm thinking that these mufflers do a pretty good job of making it quieter.
So taking one apart carefully, might reveal how we could make our own, only beefier, and quieter.
If I had an extra one, I might give it a try, but I don't want to take apart the one that is in use. It's more important right now to have the stock one on there. For me, this project would take the back burner to a whole slew of other things I have to do before I consider building a new exhaust.
Hoping someone else has carefully cut one apart, and can post some pictures. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5727 Posts : 1408 Location : Galway NY
| Subject: Re: Stock muffler teardown April 24th 2014, 2:09 pm | |
| as far as i know, its just mesh in there. also depends on what kind of muffler youre talking too though. usually we just straight pipe all our stuff. lol | |
Age : 25 Join date : 2013-04-05 Points : 4928 Posts : 661 Location : New Smyrna Beach,Fl
Angchor Member
| Subject: Re: Stock muffler teardown April 24th 2014, 2:52 pm | |
| - craftsmancole wrote:
- Later today I can cut one apart and post pictures if you want
Excellent! Thank you! | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6509 Posts : 2101 Location : Norway, Europe
Angchor Member
| Subject: Re: Stock muffler teardown April 24th 2014, 3:10 pm | |
- Looks like I dont have to cut one apart now.
That's not a standard muffler. I'd like to see the guts of a standard, square muffler. But I DON'T want you to feel like you "have" to cut one apart. Seriously. It's not like I'll use the information immediately. LOL | |
| Subject: Re: Stock muffler teardown April 24th 2014, 3:11 pm | |
But I DON'T want you to feel like you "have" to cut one apart. Seriously. I can still cut one apart I have like 10 of them laying around that I don't need | |
Age : 34 Join date : 2013-11-02 Points : 7130 Posts : 2907 Location : New Jersey USA
| Subject: Re: Stock muffler teardown April 25th 2014, 12:25 pm | |
| I could cut some up too, I saved a bunch of stock stuff that I'll probably never use. Most mower mufflers just go through a baffle with some holes in it. The bigger ones might be a little more intricate. | |
untrusty huskee Member
Age : 26 Join date : 2014-01-04 Points : 4044 Posts : 79 Location : Fulton IL
RCG Member
2016 Build-Off Finalist
B440 Member
Join date : 2014-01-22 Points : 4170 Posts : 226 Location : Thompson, CT
| Subject: Re: Stock muffler teardown April 26th 2014, 8:57 pm | |
| Here is a muffler from a briggs 12.5 hp vertical shaft engine on a simplicity 4211. Two baffles and some off set tubes. Much more elaborate than I was expecting for a lawn mower. Pretty much like the inside of a car muffler. Basicly you just want to have places for the sound to be trapped and dissapate while allowing a relatively free flowing path for the exhaust gases. | |
Age : 27 Join date : 2012-10-31 Points : 5130 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Stock muffler teardown April 26th 2014, 9:03 pm | |
| I took and ran my muffler backwards and removed a baffle and it sounds better but not straight piped. got some low tones at idle and somewhat loud at WOT.
Angchor Member
| Subject: Re: Stock muffler teardown April 26th 2014, 9:06 pm | |
| - mr.modified wrote:
- Two baffles and some off set tubes. Much more elaborate than I was expecting for a lawn mower. Pretty much like the inside of a car muffler.
Thank you, thank you!!! That is exactly what I needed. I kind of expected it to be a bit more complicated than most were thinking it would be. Because these little mufflers do a surprisingly good job of deadening the sound. Now, when the time comes, I'll have some idea of how to go about copying them, but making it beefier, and possibly quieter. Thanks again! | |
B440 Member
| Subject: Re: Stock muffler teardown June 27th 2014, 10:30 pm | |
| This muffler off a Briggs 12.5hp flathead was loud like a straightpipe. Now I know why... Replaced it with one like mainemudmower drew on the first page. | |
ThatOneTeen Member
Age : 25 Join date : 2014-05-22 Points : 3962 Posts : 144 Location : Illinois
| Subject: Re: Stock muffler teardown June 28th 2014, 1:25 am | |
| Does anyone know of a way I can quite my mower down? My neighbors will put up with all of my crazy toys aslong as they are quite. My mower is loud as heck and they dont like it | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5118 Posts : 1068 Location : New jersey
| Subject: Re: Stock muffler teardown June 28th 2014, 7:45 am | |
| i dont know if you can do this with mowers im sure you can but awhile back i had a atv. i would drive around A LOT and neighbors were getting a little annoyed so i got sos pads or steel wool whatever you want to call it stuffed it in the muffler. then took a window screen and a hose clamp stuck the window screen over the exhaust pipe and then stuck the hose clamp on the pipe to keep the steel wool from flying out it worked kept it very quiet and made my neighbors happy. | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5412 Posts : 1311 Location : NW USA
| Subject: Re: Stock muffler teardown June 28th 2014, 8:21 am | |
| - Craftsman1998 wrote:
- i dont know if you can do this with mowers im sure you can but awhile back i had a atv. i would drive around A LOT and neighbors were getting a little annoyed so i got sos pads or steel wool whatever you want to call it stuffed it in the muffler. then took a window screen and a hose clamp stuck the window screen over the exhaust pipe and then stuck the hose clamp on the pipe to keep the steel wool from flying out it worked kept it very quiet and made my neighbors happy.
that is a great idea! i was thinking the other day (a rare occurrence) and i realized that i need something I can drive without scaring the little kids. this looks like an easy solution! | |
ThatOneTeen Member
| Subject: Re: Stock muffler teardown June 28th 2014, 12:18 pm | |
that is a great idea! i was thinking the other day (a rare occurrence) and i realized that i need something I can drive without scaring the little kids. this looks like an easy solution! I will have to go and pick up some steel wool and test that out oneday soon | |
T-Dub13 Established Member
Age : 54 Join date : 2013-12-06 Points : 4538 Posts : 540 Location : Central MA
| Subject: Re: Stock muffler teardown August 26th 2014, 10:31 am | |
| The key to performance and quietness is volume. Looking at the vast array of mufflers, you will notice that the larger the muffler, the quieter it generally will be. And the better it will work for performance, being that it can deaden the sound with baffles, but not create excessive back pressure. Larger passages = better flow. High Performance mufflers are sort of an oxymoron. But Glass packs have always been the Go-To for hot rod boys since they're a straight through muffler that sounds good because the packing eliminates most of the high frequency noise. They provide a good low rumble when putting around the yard, but they will also give up a good healthy bark at WOT. This is what I'm running. Angchor: If you have room, a small automotive muffler would work great for what you're looking for. You can grab a pile of 'em from any garage. My garage has 3 of them right now in the scrap pile. Too bad you're so far away lol! edit: Also, with a larger volume muffler, you can have a much smaller outlet. Reason being that the pulses will smooth out inside the muffler and don't require a large opening to let out each pulse. So instead of emitting large abrupt pulses, the muffler will emit smaller smoother pulses, more like a whisper compared to a pop. | |
