| Briggs 16hp Opposed horizontal teardown (and possibly reassembly) | |
| | | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
| Subject: Re: Briggs 16hp Opposed horizontal teardown (and possibly reassembly) January 15th 2017, 4:06 pm | |
| Take a punch and hit it with a hammer. That will help break it loose. It may also mushroom the head and your screw drive might take it out.
Something else to consider, a hand impact driver. Might be able to get one for $20... just try not to loose it. I lost mine. Curses.
If you have a big strait screw driver, you can slot the head and try that, but be sure to tap it with a hammer and spray some penetrating oil on it.
If you get it loose and it starts to get tight again, run it back in and out a few times. Apply penetrating oil before you run it back in. You dont really want to break it off in the block. Atleast, I sure didnt.
Or better yet, you dont need those... just send them to me. | |
| Subject: Re: Briggs 16hp Opposed horizontal teardown (and possibly reassembly) January 15th 2017, 5:15 pm | |
| It's funny now that as soon as I post this, I find a like #2134123 or however big phillips head screwdriver that with a lot of pressure and arm strength I can bust them all out. Guess this is now the thread on the teardown and possible rebuild of this engine But thanks anyways for the reply man | |
| Who is online? | In total there are 33 users online :: 1 Registered, 0 Hidden and 32 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
