 Locked Spicier Hard to Turn!
apollodawg
6 posters
apollodawg
Locked Spicier Hard to Turn!  Empty
PostSubject: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 1:24 pm
Hey guys I just locked a spicier transaxle and its really hard to turn, i have to put the pulley on just to turn. Is this normal for grease filled transaxles? Should i try and brake it in or pull the cover again. BTW i did it yesterday and it was very cold, does the cold grease have anything to do with it?
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 1:58 pm
Axles are probably binding.
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 2:51 pm
Did you put the bushings in the case right? on the ends of the gear's shafts, there are bushings with little triangle looking pieces molded off of them. those go into slots in the case, so the bushing doesnt turn with the gear's shaft. if they arnt in the cases slots correctly, when the case is clamped shut it will bind.
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 5:54 pm
It certainly is NOT normal. Check the bushings as Red indicated, and cross your fingers that he's right. If not, you may have heat-warped something, rendering it a greasy paperweight.
If the bushing thing doesn't pan out, leave the cover off and turn it by hand while observing things very closely. If somethings warped, you may be able to spot it rising and falling as it turns.
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 7:14 pm
Yeah I agree.  If you take the spiders out to fully weld them after you tack it in the case, you need to make sure they are exactly how they were when they were tacked.  If they are put in different than they were tacked they would rise and fall in the case, thus causing binding.
apollodawg
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 6th 2014, 7:38 pm
ok thanks guys ill check tomorrow. It's my first time locking one and i did it the way fearless did. I nicked one of the teeth on the spider gears with my welder so ill make sure its not touching that tooth and and i'll try switching the gears around and i'll check my bushings too.
B440
B440
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 7th 2014, 10:25 am
Super-tacky grease (usually red in color) can make it harder to turn, but you should be able to rotate the wheels (on the axles) by hand and get the pulley to spin while in gear. No belt on the pulley while trying this.
Locked Spicier Hard to Turn!  053AA101EDCA35A16433268F05899A6C
apollodawg
PostSubject: Re: Locked Spicier Hard to Turn!    Locked Spicier Hard to Turn!  Icon_minitimeApril 7th 2014, 5:52 pm
i think i fixed it!  The axles were very tight so i took one of the 2 thrust washer off the short side and now it is smooth with very little play.
» Look what happens when you turn 67
» Tracked zero turn
» Stunt Hands and the Zero Turn Tug
» 18 hp Opposed twin wont turn over
» Brake lights and turn signals
