 Wheres the charge wire on a 17hp Kohler Command?????? Need Help
jamcco
jamcco
Wheres the charge wire on a 17hp Kohler Command?????? Need Help Empty
PostSubject: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 8:40 pm
Ok so I have asked some of you guys on here for help with this already but I'm still having issues. So i redid the entire wiring system on my early 2000's Kohler 17hp Command 1 single. Now the only thing i have yet to hook up is the charge wire. will someone please tell me where the charge wire is on a kohler. I know briggs are fairly straight forward but this kohler is something different. Please help, I want to go on trails without my battery booster.  Shocked
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 8:51 pm
Take pics of every wire that comes off your engine. I think Kohlers have regulators so itll look different.
jamcco
jamcco
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 8:58 pm
Yah I'm pretty sure I might of cut off the regulator (yah i know stupid) , I'm going to have to put that back on. This is what the wires around the regulator looks like.Wheres the charge wire on a 17hp Kohler Command?????? Need Help Maxres10
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 9:07 pm
Its one of those.
Go to Partstree.com and look up the tractor it came off of. They might have a wiring schematic that will tell you what color wire is the charging one.
jamcco
jamcco
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 9:16 pm
I think I've got this figured out for good now, I had the 2 ac wires left coming off the engine because i disabled the regulator. Tommorow I guess I'll hook up the ac power back to the regulator. I watched this video and it helped alot. https://www.youtube.com/watch?v=SER0Z39nLNY I didn't know that that bit was a regulator, if i did i would of never had this problem but thanks lots, I guess this is part of being new to mowers  scratch  I'm learning every day
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 9:35 pm
Some have em, some dont. Most Kohlers and Vtwins do.
MurrayMayhem
MurrayMayhem
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 9:43 pm
Well anyways, if you took off the thing that hooks on, you'd see little shapes stamped onto the metal tabs on there. One has a + on it and that's the charging wire, trace it back to the other side of the mower.
jamcco
jamcco
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 21st 2014, 9:54 pm
Well I guess I know what I am doing tommorrow morning  Very Happy  Thanks
jamcco
jamcco
PostSubject: Re: Wheres the charge wire on a 17hp Kohler Command?????? Need Help   Wheres the charge wire on a 17hp Kohler Command?????? Need Help Icon_minitimeMarch 22nd 2014, 8:10 pm
ok so hooked up the white wires (the ones i cut.) i then proceeded to check out how much voltage is coming out of the middle wire which i assume is dc. my multimeter only read .15 volts. this doesnt seem right can someone explain to me how to hookup a lawn mower regulator to a mower that has had a wiring system done like fearless's?
» kohler command 12.5 problems
» 15.5 HP Kohler Command Being Dumb.
» Kohler Command 13 ohv governor question
» Get more horse power out of a kohler command
» Kohler command 20 "governor hunting"
