 T-Dub's exhaust system project
T-Dub13
6 posters
T-Dub13
T-Dub13
T-Dub's exhaust system project Empty
PostSubject: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 12:20 pm
Well Guys, I finally got to building an exhaust that's worthy of being bolted onto the 12+hp flatty I built.
I was originally running the stock canister muff, but felt that my tractor needed something better, louder, cooler, you know something like...  A GLASS PACK!
Here's the pile I started with...  Note the Bicycle forks which is what I ended up using...
T-Dub's exhaust system project Collectingexhaustcomponents_zps074ad25b
I fitted the original canister to the exhaust port when I built the motor, so I could use the spigot at a later date.  This is the form that fit the exhaust port best, so I'm keeping it!
We know that the port exit is too big.  There have been discussions about filling the threads with epoxy and other innovative fixes.  I figured I'd just use what's there since it's extended inside a good ways.
T-Dub's exhaust system project Exh3_zps011d8016
Tracing out the form.  Using the original gasket.
T-Dub's exhaust system project Tracinggasketb_zps92bcb9d2
Cutting the spigot off of the can.
T-Dub's exhaust system project Cuttinginsertpipe2_zpsa207e7a0
Marking the spigot for proper alignment.  Front is front. (actually that's the rear. I have it marked wrong!) glad I cought it in time!
T-Dub's exhaust system project Aligningpipe_zps936339d3
Cutting.
T-Dub's exhaust system project Cuttingflangea_zpse46e0367
Punched and certerdrilled.
T-Dub's exhaust system project CenterDrill_zps6c04dd56
Nice sharp drill!  If you're not getting pigtails from your drill, you're wasting time!
T-Dub's exhaust system project Sharpdrill_zps1e95a84a
Step drilling the port hole.  (see the mistake I made)?  I hit the vise with te tip of the drill OUCH!
T-Dub's exhaust system project Stepdrill_zps8b6eac38
Hogging with a burr.
T-Dub's exhaust system project Hogginitout_zpsd794b61a
Fitting and aligning the spigot.
T-Dub's exhaust system project Positionthepipe2_zps4c2110ec
Tacked.
T-Dub's exhaust system project Checkingagain_zpsc843bea5
Test fit and then seam welded.
T-Dub's exhaust system project Boltedon_zps489afe7d
Time to prep some header pipes!
T-Dub's exhaust system project Bicycleforks_zps7e40f1e8
Cleaned up nice.  Not bad for junkyard headers huh!  Notice the handlebars from the Ariens Snowblower..  Double walled OH NO!  Can't use them, so I'm going to be short one curve.  Hmmm
T-Dub's exhaust system project Cutandcleaned_zps69263d72
First section tacked on.  Looks like a drag racer lol.
T-Dub's exhaust system project Header1_zpsaf7802da
Second section tacked.  Looks good so-far.
T-Dub's exhaust system project Checkingclearance2_zpsa7123907
Checking for clearance.  I should put on some steering stops!
T-Dub's exhaust system project Checkingclearance_zps4cb277b6
Time to fit the Glass Pack. Tough angle without that extra cruve from the handlebars...
T-Dub's exhaust system project Fittingcherry1_zpse8ed2d19
Fitting the joint.
T-Dub's exhaust system project Sectioningcherry_zps019eb6d5
Checking.
T-Dub's exhaust system project Sectioningcherry2_zps6e95cba5
Notching.
T-Dub's exhaust system project Sectioningcherry3_zps7c7bba10
Tin knocking.
T-Dub's exhaust system project Formingcherry_zps9eda14d5
Here's what the inside of a Glass Pack looks like.  The center tubeis perforated so the high frequency sound waves go into the fiberglass and ger absorbed.  All that's left to come out the other end is low frequency.  That's why I think glass packs sound so good!
T-Dub's exhaust system project Lookinsidethecherry_zpsef11f29b
First try at hanging the 'pack.
T-Dub's exhaust system project Hanging_zps19c84ea8
So, here's what it looks like now.  Sounds great.  I'll get a vid of it hopefully later today.
T-Dub's exhaust system project Withoutpipe_zpsbb9a1bd1
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:01 pm
Looks good! VERY good... Is there a brace or bracket for that muffler, that I cannot see? Looks sort of familiar too... Here's an old pic of mine right after I did the exhaust (on original engine- which, by TOTAL coincidence, was a Briggs 12hp flatty). Note that my Cherry Bomb is homemade, and does NOT contain glass. And YES, I had to add steering stops due to the pipe and the larger tires I installed (after this pic was taken) Also- be sure that the dog doesn't walk off with your tractor. LOL
T-Dub's exhaust system project Exhaus10
Last edited by Doc Sprocket on January 31st 2014, 1:07 pm; edited 2 times in total
PostSubject: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:05 pm
good job! I may have to do something like this for my murray's exhaust, it's way too quiet. good writeup!
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:06 pm
You know what they say: "Great minds think alike" lmao! That looks like a great system Doc!
Do you have any vid footage of the sound? Mine's mellow until you get into higher revs, then it barks pretty loud.
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:08 pm
Thanks guys. It's hanging a little low and still raw steel. Got some painting and exhaust hanging to finish up the project. My feet and hands were numb by the time I got this far last night.
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:31 pm
I originally built the muffler for a Honda GX340 (11hp) Honda OHV powered go kart. I'll look around. I DID shoot a quick clip of the sound. Must have it somewhere.
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 1:36 pm
Oh yes they DO! Wink
There's info on my Cherry Bomb and a short video clip here. The crappy audio doesn't really do it justice, but you'll get the idea.
http://www.diygokarts.com/vb/showthread.php?t=7449
That was an old YouTube account of mine. Not using it anymore. I need to go through it, transfer what I want, and dump the rest.
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 9:04 pm
Well, your vid came out better than mine!  I don't hink the microphones on any camcorder is good enough to get the full effect.
I used my phone so even worse.  The high frequency noise is all the drivetrain in neutral with a grumbly bearing in the idler....  Eh whatever, you can sort of hear it!
Vid of the Glass Pack
Wow, that vid is horrible LOL!! I'll have the kids vid me tomorrow with a better camera on a high speed run down the street. Stay tuned!  Cool
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 9:20 pm
for anyone looking to make a glass pack, the expanded metal mesh with the bumpy surface works well for the internal perforated tube. Put the bumps facing the exhaust port so the flow goes into the glass)
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeJanuary 31st 2014, 9:53 pm
I like the final produce, and the use of that bike fork  cheers
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeFebruary 1st 2014, 1:42 am
so, you think 2 of em would sound good with a 18 hp oppy?
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeFebruary 1st 2014, 1:39 pm
Dunno 'bout him, but I think it would!
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeFebruary 1st 2014, 9:35 pm
YEP!  cheers
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeFebruary 1st 2014, 9:54 pm
YEP!   cheers
nice, in the vid you posted it sounded like it has a deep rumble sound to it
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's exhaust system project   T-Dub's exhaust system project Icon_minitimeFebruary 1st 2014, 10:04 pm
Yes it does.  That's a glass pack sound.  I had a BUELL motorcycle.  V-twin Harley Sportster engine built to 110hp.  I ran 2 into 1 into a Vance and Hines Glass Pack.  Sounded amazing.  I'll look for a similar vid so you can get the idea, but I bet you could get a V-twin or oppy to sound similar.
Well I posted a vid... Buells rev pretty high compared to a B&S but it's a pushrod motor so that's their limiting factor. Good for about 6000rpm. Same parts inside this guy's motor as I had haha.
2-into-1 glass. You can see it under the motor.
» Downturn exhaust?
» Exhaust tips
» Tater's "OH Deere 116 dragster" [2017 Build-Off Entry]
» Backfires when brought to low idle
» New exhaust
