| reg belt vs. Kevlar belts | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5756 Posts : 1408 Location : Galway NY
| Subject: reg belt vs. Kevlar belts January 25th 2014, 12:59 pm | |
| hey yall, just looking for your thoughts on kevlar belts. is there any advantage to running kevlar over standard lawn and garden belts? im just poping the NAPA lawn and garden ones like theyre rubber bands | |
Age : 37 Join date : 2013-07-02 Points : 5014 Posts : 731 Location : Logan Ohio
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 1:35 pm | |
| I've ran slot of belts over the last ten years and my favorite is gates "green" power rated belts | |
Age : 25 Join date : 2013-04-05 Points : 4957 Posts : 661 Location : New Smyrna Beach,Fl
| | | | Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6538 Posts : 2101 Location : Norway, Europe
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 5:58 pm | |
| Fancy name, anyone know the exact difference, im guessing the "kevlar" belts have strands of kevlar instead of some other fiber / aramid mix bound in htem, -For strenght. It should'nt do that much for the grip tho. | |
Age : 49 Join date : 2012-04-05 Points : 5696 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 6:32 pm | |
| We run standard 5/8 belts, on 6 in pulleys. They usually last a couple of years.
Small pulleys, slip, high tension, misaligned pulleys, bent/rough pulleys will shorten belt life, sometimes to very short belt life. | |
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 7:30 pm | |
| mine last about 3-6 months depending how much i run it. that seems hella short. they just snap... one of the pullys is kinda small but i cant do anything about that, cause its a double pully. its got a big one and a little one casted together. same on the engine side. any tips on how to align them? its a horizontal shaft | |
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 8:47 pm | |
| Eye ball it, make sure everything is inline, and parallel. Are you using 5/8 belts?
I'm not a fan of double pulleys, seems like it's a lot of extra twisting for the belt.
Would need some good pics of the belt routing/pulleys | |
| Subject: Re: reg belt vs. Kevlar belts January 25th 2014, 10:25 pm | |
| no, i dont mean double clutch, there is 2 on the driveshaft and 2 on the engine crankshaft, they serve as my high and low. i can get pics probably tomorrow. the best way i can describe is a stacked pully heres a rough sketch. like i said, i'll get actual pics tomorrow | |
| | | | Sponsored content
