 Belts rubbing to much! HELP!
WilliesBuilds
WilliesBuilds
Belts rubbing to much! HELP! Empty
PostSubject: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 10:54 am
Do I need to put a belt tensioner in or what . Im not sure how to fix this the belts almost touch eachother
Belts rubbing to much! HELP! Gopr0712Belts rubbing to much! HELP! Gopr0713
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 10:57 am
Are the belts actually rubbing?  It does not look like it.
If they are, an idler or tensioner would work... just make sure you aren't causing it to rub elsewhere in the process.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 11:02 am
yeah there not rubbing together but its rubbing on shift barrel coming from the transaxle. should the idler pulley be on the clutch side or on the other side?
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 11:03 am
I just don't know if this is something to worry about it, it hasn't caused me any problems as of yet
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 11:06 am
If it's not messing up your belts, I wouldn't worry too much about it.  And the idler can be on either side, just put it in a place to deflect the belt enough to avoid rubbing.
Chaos Build
Haspin 2021 thread
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 11:09 am
Thanks Man! appreciate the help
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 4:03 pm
If its rubbing one something just add in another idler pulley to move the belt away from whatever its rubbing on. Your clutch looks like its on the right side but I think I see where you say its rubbing. Just add in a V idler on the side thats rubbing, but not so much that you need a new belt, just enough so that when you let off it doesnt rub.
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 20th 2013, 4:12 pm
hmm ok man im definitely gona look into doing that . Thanks !
Mowerkid
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 23rd 2013, 1:49 pm
Hey I have a murray and I did a 4inch pulley swap on the transaxle. from underneeth it looks identical to yours and I have the same rubbing issue. I've been riding it like that for a while and i havn't had any problems, tell me what you do to stop the rubbing.
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 23rd 2013, 5:13 pm
the easiest way to get rid of the rub since you shrank the pulleys, is... get bigger ones. So like, if you run a 4" front and rear, go to a 6" front and rear. Same ratio, different curve. Will also help with any belt slippage you may be experiencing too Smile
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 24th 2013, 11:31 am
Thanks for the advice ill look into that . But I'm running a 7or 6 inch on the engine not too sure ,and a 3 or 2 inch on the transaxle is that a good ratio or should I make the transaxle pulley larger
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 24th 2013, 11:38 am
I moved this topic to its appropriate subforum.
Chaos Build
Haspin 2021 thread
WilliesBuilds
WilliesBuilds
PostSubject: Re: Belts rubbing to much! HELP!   Belts rubbing to much! HELP! Icon_minitimeJune 24th 2013, 12:45 pm
Thanks man !
» Twisted Belts?
» Prancstaman's X1 Scorpion
» Measuring Belts
» Belts vs Chain
» craftsman keeps shredding deck belts
