| Measuring Belts | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5747 Posts : 1993 Location : Northern Ireland
| Subject: Measuring Belts September 25th 2016, 3:49 pm | |
| Hi, Looking to measure a belt for a riding mower. Checked Doc's thread, 'The Right Belt, Every Time' and noticed he used a belt gauge but can't seem to find where to buy one. I am looking for alternate ways to measure a belt. I'm going to get a longer built, cut it down and cable tie it up to the right size. Any ideas on how to measure that belt? | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8581 Posts : 5190 Location : Ontario Canada
| Subject: Re: Measuring Belts September 25th 2016, 4:50 pm | |
| Well it may seem a bit unorthodox, but the way I did it was I clamped the shaft of a screwdriver in a bench vise, hooked the belt on the handle of the screwdriver, pulled on the belt as hard as I could and measure (or have someone do you for you) from the screw driver to the other end of the belt and that will give you the approximate length of each side, so you just gotta times it by two. This doesn't really sound like it would work, but it worked for me. Just a suggestion. Good luck! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Measuring Belts September 25th 2016, 5:35 pm | |
| That actually seems like a good idea. I will try that. | |
| Subject: Re: Measuring Belts September 25th 2016, 6:03 pm | |
| Cool, glad to be a help. Let me know how it goes! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5975 Posts : 2645 Location : Indiana
| Subject: Re: Measuring Belts September 25th 2016, 8:28 pm | |
| Hardware stores like Tractor Supply Co. have them in their belt section mounted on the shelf. just bring in the old belt and use it to measure your new one. We couldn't find one that fit the CQ in our collection, so we brought one slightly big, measured it, and got one an inch shorter. Hope this helps! | |
| | | | | Measuring Belts | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
