| 18 hp vanguard choking out | |
+2redlinemotorsportts Dipshaw87 6 posters | Author | Message |
Dipshaw87 Member
Age : 29 Join date : 2014-01-02 Points : 4151 Posts : 135 Location : Vanderbilt, Pa
| Subject: 18 hp vanguard choking out January 12th 2014, 10:05 pm | |
| How do I keep the engine from choking itself out when I mash the gas? | |
Age : 27 Join date : 2013-03-18 Points : 7477 Posts : 3131 Location : raleigh nc
| Subject: Re: 18 hp vanguard choking out January 12th 2014, 10:18 pm | |
| Sounds like a carb problem, clogged and or dirty. id disassemble it, clean it, and re assemble and go from there. | |
| | | Dipshaw87 Member
| Subject: Re: 18 hp vanguard choking out January 12th 2014, 10:24 pm | |
| I just recently cleaned the carb on it and it's still on the factory throttle setup with the governor. Is there an adjustment for the governor arm so that when I hit the gas to full it won't choke out then pick back up? It's a mikuni carb so if I need to adjust anything how would I adjust the carb? I seriously need help lol this motors a lot harder to me than a 12.5 I/c | |
Age : 28 Join date : 2013-04-10 Points : 5755 Posts : 1408 Location : Galway NY
| Subject: Re: 18 hp vanguard choking out January 13th 2014, 8:36 am | |
| define "choking out". if it chokes out, there will be a degree of backfiring, black smoke, and the smell of raw, un-burnt fuel in the exhaust. try leaning it out the main jet just a little, also make sure the air filter is clean | |
| | | Dipshaw87 Member
| Subject: Re: 18 hp vanguard choking out January 13th 2014, 12:44 pm | |
| Whenever it's warmed up at idle and I hit the gas to run full throttle there's like a second worth of hesitation before it revs up | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7776 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: 18 hp vanguard choking out January 13th 2014, 3:20 pm | |
| The governor makes it hesitate slightly. Mine does it too when you mash, and so does my truck. Its just how carbs work. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Doc Sprocket Site VIP
| Subject: Re: 18 hp vanguard choking out January 13th 2014, 4:56 pm | |
| Although this has been said before, I'm gonna say it again- make sure the carb is clean, fuel flow is unrestricted, and intake gaskets are in good shape. It may be slightly lean. Now-
On the flip side- no matter WHAT you do to a factory carb, do not expect lightning throttle response. This design of carburetor once powered dinosaurs, I swear.
They only have two circuits: The pilot (idle) circuit, and the high-speed circuit. It doesn't take much imagination to figure out that there's a LOT of range in between idle, and WOT. Yet, this is what we have to work with. There is nearly ALWAYS a lag between idle and WOT, when the throttle is opened abruptly. Depending on multiple factors, it may or may not be particularly noticeable.
Performance carbs are different animals. To illustrate an example- the Mikuni VM series often found on motorcycles, have FIVE circuits which overlap each other- MUCH better throttle response, but a pain in the @ss to tune. Everything comes at a price. | |
| | | Dipshaw87 Member
| | | | T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4566 Posts : 540 Location : Central MA
| Subject: Re: 18 hp vanguard choking out January 14th 2014, 10:17 am | |
| Are you saying that the throttle linkage is actuating the choke at full throttle? (some tractors have the choke above the bunny rabbit on the throttle control).... If this is the case, you can either eliminate the choke linkage or limit the throttle cable travel. OR are you saying that it just dies when you stomp on it? This would be an indication (like Doc said) of an archaic carb that only has two circuits and no accellerator pump. We know your idle is lean because of the vid you posted in the other thread. So, get it to idle correctly first, then adjust the high speed circuit. (Most tuners will do this twice because the circuits do influence eachother slightly). Good luck and keep us posted! | |
| | | Dipshaw87 Member
| Subject: Re: 18 hp vanguard choking out January 14th 2014, 10:21 am | |
| I'm not exactly sure if it's setup to open the choke slightly or not. I did tune the high rpm circuit and the low circuit and it seems to have cleared up a little | |
