 12.5hp vanguard
lawnguy17
Shawn1750
greener179
7 posters
greener179
greener179
12.5hp vanguard Empty
PostSubject: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 10th 2012, 11:44 pm
i can buy a 12.5hp briggs vanguard for 50 bucks it ran when removed 2 years ago good or bad deal?
Shawn1750
Shawn1750
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 12:40 am
I say it's a great deal! If it's a sound engine! Any oil leaks?
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 12:49 am
not that i know of he said its pull start and ran when removed he didnt know how old it was but how long have vanguards been around? and whats the difference between a vanguard and a normal engine?
Shawn1750
Shawn1750
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 1:20 am
I thought the Vanguard engine was newer with overhead valves? Being a 12.5 hp pull start, my guess is it's an old flathead engine. Either way, it's still a good engine, providing it doesn't burn oil or leak.
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 1:54 am
i think its a newer engine the dude seemed sure it was a vanguard either way i wanted pull start never have to worry about a died battery cheers
Shawn1750
Shawn1750
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 3:37 am
Cool! Just look at the label.. If its a Vangard, it will say so!
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 11th 2012, 9:19 pm
it was a vanguard didnt leak oil idk if it burns oil yet got to clean carb ended up getting it for 35 dollars cheers
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeSeptember 14th 2012, 8:51 am
almost got it mounted thing is a tank compared to the original 8hp
lawnguy17
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 5:48 pm
they are good engine I own one instead its a v-twin from 1989. seems like an awesome buy. I got mines for 75$ all I had to do is clean the carb and a new fuel pump. just as long as it dosent smoke and has spark you are set to go.
CornishMorgan
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 6:05 pm
Good job, I wish I could get an engine that cheap.
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 6:09 pm
Briggs V-twins are some nice engines. My friend has an 18.5 Intek and it cranks. I still need to clean my own 14 Vanguard, got it for $25 in a Craftsman II body, although my engine is a bit rougher I believe.
Make sure you clean out those jets!
Also if your ID label is still on the blower housing, this will help you find out its characteristics, as well as the make year.
http://www.jackssmallengines.com/briggs_and_stratton_model_locator.cfm
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 6:53 pm
I took this engine off of the mower because it always blows the crankshaft seal
lawnguy17
PostSubject: vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 7:12 pm
cool. you should clean it up it proves to be a good engine
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 3rd 2013, 10:32 pm
I wish i could get the seal so it dont blow
tractorboy567
tractorboy567
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 4th 2013, 10:16 am
as long as its not in pieces then get it
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 4th 2013, 12:54 pm
I have had it for about 4 months now its a good runner just it blows the crankshaft seal any ideas how to fix that problem
Chopperhed
Chopperhed
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 4th 2013, 2:30 pm
make sure the crankcase vent (pcv System) is not plugged or blocked. and make sure the crankshaft bearings are in good shape.
greener179
greener179
PostSubject: Re: 12.5hp vanguard   12.5hp vanguard Icon_minitimeFebruary 4th 2013, 7:43 pm
Ok i will check that but when i had that motor on my mower it had alot of power i could idle it down and floor it it would raise the front end up.
12.5hp vanguard
» 22hp vanguard running problems
» E3 spark plugs for vanguard
» Vanguard vtwin exhaust
» 14/16 HORSE VANGUARD CARB
» Vanguard 18/20 hp Parts Hack!
